Start to finish, removal to installation should take like 15-20 minutes. I'd advise to do that in one go as it's opening the internals to the outside environment.Alright so remember I get to work on this like in small timeframe increments. Once I remove the old seal I can leave it like that for a while until I have more time to install the new seal?
Alright I’ll make sure it can all be done in one goStart to finish, removal to installation should take like 15-20 minutes. I'd advise to do that in one go as it's opening the internals to the outside environment.
Haha ya the never ending job!If you discover on your next drive that there is a cooling issue; Your fan and pulleys are under the car.![]()
I have not put the crank bolt in yet. Before I do… anything look off to anyone? I’ve read to torque the crank bolt down to like 90ft/lbs, is that correct? Do I put blue loctite on the crank bolt? RTV on the keyway?
One other thing. My balancer came with a new one of those timing light contraptions… can I leave the original one on or do I have to replace it as well?
Same RTV I used on the crank seal in the key way as well? Or did I miss that step by putting the balancer on first?All of that is fine.
What I do:
Loctite on the crank bolt
Thread it on until it bottoms out / Use a wrench to ensure that it bottomed out
Apply the battery operated FU wrench and DUGGA DUGGA until the beat is consistent.
