If you have jack stands under the rear end then place the jack under the pinion of the rear end. Remove the other UCA and get the bushing replaced on the rear end. Use the jack under the pinion to rotate the rear end to get the bolt holes to line up. Do not adjust this while being under the car.
This will change the pinion angle back to factory as I’m sure that was out with the worn bushings.
