Coyote Swap on a 1991 Fox Vert
Blueinfan
259
60
38
Temecula
Hi All, I live in Kalifornisky (CA) and looking for some help. Do any of you know who can do a Coyote swap for me with everything legal?
i have a 1991 Fox Vert that i would like to swap over to a Coyote?
thanks!
I have read that it is but you have to put every emissions part from the donor vehicle into the car its going in. They also said that it is best to go to a referee before you do the swap and get advise on what they will be looking for. If you get the VIN off the donor vehicle or one identical to it that will help the referee guide you and then tech the car when you bring it to them.
I live here in SoCal. I researched this swap a while back, but to to swap a Coyote into a 94-95 chassis. Ford sells a standalone PCM that's designed for a swap into cars like ours, that have a 'return-style' fuel system. But that PCM is not smog legal in California, so you can't just buy a crate engine and the associated parts. You need to get an engine and PCM from a donor car, AND take all of the related emissions parts from that car. Here's a link to a forum post that details many of the things you will need for the swap:
Check out the whole thread for more info. This person removed the floor of his Fox and welded in the floor from the Coyote, and also swapped in the Coyote's interior. This may be more than you're willing to do. Also note that you'll have to have the swapped car inspected by a BAR referee, and they require proof that the Coyote's PCM code has not been modified. Meaning you'll have to install the Coyote's PATS system and anything else the PCM requires to run. So again, it's not easy to do a Coyote swap here in CA.
I don't typically mind emissions rules. But preventing people from using newer cleaner powerplants makes no sense. My car passed nj emission standards (when we had them for 95 and older cars) with no cats and a terminator swap.
IMO, it should be a sniffer check only. So long as it meets or exceeds OEM specification for the model and year, press on with pride. :shrug:
Thank you! that does make sense.
It still blows my mind. I grew up in SoCal. In HS, I drove a 58 Chevy pickup truck with a 68 Vette 327 and wheels. Straight pipes, 3 on the tree, passenger door roped closed, primer grey, and at least two people riding in the open truck bed all smoking what looked like cigarettes at 90+ mph. :shrug:
Can't even swap an engine anymore. :doh:
Stangnet, the land of angry old divorced guys guys that can't keep their politics about things that don't even affect them out of other people's threads...
What goes on in Cali could easily happen in any state so I'm all for the EPA to be stripped down. Nothing about politics. Just be lucky you're from Jersey like I am and can run no cats all day..
Oh you can still swap an engine, you just don't want to
