1990-1991 is single digit codes. 1992+ should be 2-digit codes. There are no 3-digit airbag codes.
Problem is I don’t see a code 35 listed anywhere. The 94+ system is completely different so can’t cross-reference that.
Gonna search around a bit more.
Edit: on the 1992 codes…diagnostic monitor internal fault is code 53.
Can you take a longer video so we can see the sequence repeat? Looking to determine if it’s a code 35 or a code 52.
The diagnostic monitor is a common failure. These units are getting old and likely need recapping like the ECUs.
