Progress Thread Prime's 87 T-top Gt
So... How far are you taking this?
What do you have in mind?
Where is your list of ":poo: to do"?
There's definitely a list.
Chassis: K-Member, control arms, coilovers front and rear, fix floor rot, POR any spots that don't need new metal.
Brakes: all new lines, ABS, hydro boost, recondition the M2300 calipers
Interior: complete refit, RTX gauge cluster, modern stereo, lose the A pillar gauges
Engine: clean it, fix any leak points, new cooling system, refit OE aircon, 24lb injectors, replace broken fuct wiring harnesses, 3G alternator, Cobra intake, long tubes, Borla catback
Transmission: clean and reinstall. Keep the B&M shifter.
IRS: a couple of MM parts, replace pinion seal.
Cosmetic: clean/repaint engine bay, the general exterior gets a gentile refresh. Not perfect, but pretty.
Its a lot. But it's gonna be good.
Reactions: Noobz347 and gkomo
It's not as bad as it looked. Surface rust only. The inner seam of the front frame is a bit distorted. Gonna clean it as best I can. Fix the stressed weld and maybe add a few more.
Reactions: 85GT4V and gkomo
Nice. Quick tip on engine paint that I learned over the years. After clean / prep, do a final wipe with wax / grease remove (like Prep all) sprayed on a link free paper towel. Once it evaporates, use a heat gun to warm the surface being painted. First reason, if you missed any grease / oil - you'll know right quick. Also heating the surface and making the paint flow on smooth. Lots of light coats. You can use heat gun between coats, helps off gas the propellants and set it up. Here's the 302 I did for the Bronco I restored. Engine still looked great when I sold it 15K miles later.
