Progress Thread 2004 Comp Orange GT
Only had a few minutes to mess with the Gyraline - there's a learning curve, but first impression is I like it. A lot.
Got sidetracked from the alignment issue with a nagging throwout / release bearing noise. Replaced the clutch cable when I got the car a couple of years ago. Old cable was stretched. It already and aftermarket quandrant and firewall adjuster. It's been fine with an adjustment now and again. Recently the bearing started to make some noise.
Even after clutch adjustment - still noise - Only with clutch engaged (pedal up) - at idle I can hear a slight chirp from the bearing. Almost ANY amount of of pressure on the pedal, noise goes away. Adjustment checked / rechecked. At 117K miles (105K actual - last owner drove 48K miles with the speedo fast because of the 4.10 gears) I figure it's about time regardless.
22 years of service is pretty good.
So I started shopping around for a clutch. Many everyone has an opinion LOL.
4.6 2v, Bassani headers / exhaust, JLT air intake, C&L plenum, Accufab Throttle body, 4.10 gears. Stock clutch is still fine - just the bearing noise. No need for a monster twin disc setup so I went with OEM equivalent.
Ended up with the Perfection Clutch / Zoom clutch kit, Ford Performance clutch fork, release bearing, release bearing, pivot ball and a LUK OEM replacement flywheel. (Only place that could even GET to resurfacing the OEM flywheel within a week or two wanted $90. new flywheel was less than $150 with expedited shipping).
All in for @ $600 - all new parts including a new rear main seal, since I'll be in there anyway.
Reactions: squeak93 and gkomo
Started the clutch job a few days ago. I can drive my wife's car if needed, so no need to thrash all night. Spent most of a day off simply cleaning and organizing my shop. I HATE looking for a certain tool and it's not where it's supposed to be, simply because I didn't put it up after or in the middle of a projects. It's part of the reason I have multiples of certain things - I get aggravated looking and order another.
Got the workbench cleared off and clutch parts waiting patiently.
Got the car up on jack stands and finally started tearing into it. The Bassani headers, X-pipe etc have been on this car since '05. I knew I'd be in for a battle getting this stuff off. Didn't want to just cut everything off and then weld it all back. After dealing with some stubborn band clamps, got the x / mid pipe out
Got wrapped up in some other stuff around the house, and was working on the car in spurts. Long story not so long, ended up buying a cheap cordless Amazon impact. I have a monster air impact, that I've had for years, and I'd been contemplating a Milwaukee 1/2" - since I've had a 1/4" impact driver forever (and use the hell out of it for just about everything) plus drill etc - so getting something that used the same M18 batteries / charger seemed to make the most sense. $250+ for the bare tool, then seeing reviews etc. Never made a decision. Ended up watching a random Youtube video where these guys test impacts (Big names) that's basically all they do. They were joking about this cheap Amazon tool and they tried it - and suddenly they weren't joking anymore.
Out of curiosity I checked it out on Amazon and somehow I had a $50 credit - so this thing cost less than $40 and it came overnight. Figured at worse, I'd try it and return it if it sucked.
Case, two batteries, charger. Batteries came charged. This thing rips. Lugs, chassis bolts etc - it's made be question if things were torqued correctly in the first place. So back at it.
The other morning decided to utilize my 6 ton stands in front and my big 12 ton truck stands on the rear axle tubes and got the GT up higher
So I'm humming along, unplugging harnesses, routing them out of my way, drained the trans (fluid change was recent so I saved it for reuse) dropped the trans mount, got all the hard bellhousing bolts out etc. I get the trans jack under the trans and realize it's not coming out with the RH / passenger header installed.
Bad pic - but these headers were originally installed as separate pipes. it routes around the bellhousing. NO WAY the bellhousing can back enough to clear the Pressure plate to drop down. After reconsidering my life choices - I decided to stop procrastinating and drop the K member - it's not like it takes a tong of time.
Tearing suspension out (control arms, balljoints, outer / inner tie rods, struts, springs, brakes all replaced back in '23 after I bought the car).
I should have taken the time to paint those parts when they were new. Three years of daily driving. Rinse repeat on the other side, got the rack out and zip tied it to the swaybar out of the way, supported the engine and out it came.
Here's what I'm dealing with - bad pic - as far as clearances to get headers bolts on the RH side
After figuring out the bolts were 5/16 12 point ???? - was able to get them out without too much drama. Mainly shorty / ratchet flex head wrenches and sneaking 1/4" sockets / extensions through certain spots. If I had a superpower, I might waste it on being able to make my arms super long and super skinny and triple jointed at will.
More room. With only the support bar supporting the engine now, with the K member out, I decided as an extra precaution to support the engine with a floor jack / 4x4 under the oil pan. Transmission on trans jack, trans mount dropped, last two BH bolts out, it started coming back. Then I realized the LH O2 sensor in the header collector was in the way. Turns out I already had a replacement on hand for that, so I cut the harness and mangled it enough on top (no room to get impact or even double wrench / O2 sensor socket on it now) to get the trans back and down to clear the tunnel.
Trans it out. Not quite enough room to get the trans out while on the trans jack - and don't think I really care. I can move it out of my way and it only needs the fork / pivot ball / release bearing installed.
The clutch is ALL original. 22 + years old. Lived with 400HP (Vortec) for 40k+ miles back in the day. Currently at a tick over 100K. Still in great shape. The release bearing? It was SHOT. I got to this thing just in time, I don't know how it didn't blow apart.
Some wear on pivot ball. But pressure plate, clutch (OEM Ford pt# intact + Valeo stamping) and flywheel in good shape to be honest. The pilot bearing? Not so much.
They put the wrong flywheel on my car - my car is orange. :jester:
Rear main seal is actually dry - but around the plate? No so much. I already planned on new RMS, so I'll clean it all up and install new.
Went to get my pilot bearing puller - and the narrow teeth - one of them is broke off. Wondering if I lent it to someone. Didn't want to borrow a tool from the neighbor, it was late, I wanted to get it out before I knocked off, so grabbed a hot dog bun, cut the handle off an extra alignment tool I had and a few minutes later it was out.
Inside of that bearing was rough, even before the addition of bread LOL.
Did get the K member cleaned up and any bare metal / primer or surface rust spots, I hit it with some rust converter paint I had laying around. Might rattle can it black if I feel like it.
Hopefully get back it tonight........
Holy hell thats a lot of work!
Wasn't as bad as most make it out to be. I was taking my time. I get aggravated when I have to hurry. BUT if I HAD TO - if I was JUST dropping the K member out in probably an hour or so? It's honestly not hard if fasteners cooperate.
- wheels
- hang calipers
- rotors
- outer tie rods
- sway bar bushing
- struts
- ABS sensor
- Springs
- Rack and pinion (hung from swaybar with zip ties)
- Motor mount nuts
- (8) K frame bolts
Don't think I missed anything.
Honestly? After doing this - when I yank the engine in this thing? I'm dropping the entire drivetrain out the bottom. Remove K Member, disconnect wiring harness / hoses, drain cooling system, rig something up on the ground, lower car, remove engine support bar.
Dropping out the bottom is great as long as you can get the car high enough to get it out. Can always be like the f body guys and stand it up on rear end with a ghetto winch setup. I prefer stabbing engine, trans, headers all in one shot through the top. Takes a few hands but is done in 5 minutes.
So let me catch this thread up. I was able to get out to the shop hit or miss - with work and other stuff. With the K Member out there is so much room. I was fighting the urge to make a big list of "Might as well since I've got the K member off". Not now.
Got the K member dropped, cleaned up, treated any posts of surface rust / seams etc. Now onto the RH header.
This is what access is like - with the K member out
Keep in mind, the Bassini were built as separate primary pipes that could be bolted in place one at a time, for ease of installation, then a slip on collector (with a recommended application of high heat RTV on the ends of the pipes themselves) then collector is held in place by the pictured bolt that goes through a tab on the collector itself and a tab welded on one of the primaries. Nothing wrong with any of that - but they've been in place for 20 years.
The idea of trying to get those primaries loose from that collector - much less with the header installed on the car - then expecting them all to go back together without a fight? LMAO.
So even with the K member out, access was a bit tight, but doable after figuring out which way to attack each bolt. These were 5/16 head 12pt bolts. Someone was nice enough to install anti-seize way back when, so once I was able to use a combination of drill attachment wire brushes / flex heads etc to clean the bolt heads up, I was able to get to most bolts with a stubby ratcheting 5/16, a flex head ratcheting 5/16 wrench or a long skinny 5/16 ratcheting wrench w/o a lot of drama.
Last bolt - top side rear most cylinder was the last to come out - once I figured out the angle it wasn't horrible.
And it's out
Corrosion was all just surface. I debated replacing them while I had everything apart....and the choices of headers for the 4.6 in this platform isn't great. $1600+ for BBK + midpipe, Kooks and American Racing make them too. Right under $2K for those setups. I even briefly considered just buying replacement exhaust manifolds. This is a daily driver after all. Turns out - good luck finding a new LH exhaust manifold for the round port 4.6 2v w/ EGR. I couldn't find one. Found part #'s - not stocked anywhere. Had a friend check to see if he could order it direct from the supposed supplier - their response was backordered w/ no known date of resupply. So I figured I'd clearance the header enough so the trans could clear in the future.
Anyway, back to the reason this all started in the first place. The noisy throwout bearing. With the engine supported by the support bar, and I also added a floor jack with a 4x4 on the oil pan - just to stabilize it a bit more, the trans came out without a lot of fight.
Honestly not in bad shape at all. 100k / 20 years.
Flywheel wasn't in horrible shape either. No real hot spots, no cracks etc.
Even the OEM clutch looked good. Marked / stamped Valeo.
Makes sense - it wasn't slipping or anything of the sort. Just a throwout / release bearing getting louder and louder regardless of clutch cable adjustment.
Rear main seal appears dry - but since I'm in here, it will get done. Going with a Fel Pro PTFE. I've had good luck with them in the past. Once you get past the idea of using ANY lube on the crank / seal or outer side. I read an entire tech paper from an engineer talking about PTFE seals. Turns out it needs clean, DRY, crank surface. The PTFE also needs to sit around that crank after install for at least several hours - without being run. Apparently it conforms to the crank and on first start up, a bit of PTFE 'burns' into the surface of the crank and that's what seals it up. These are apparently hugely successful in high mile / high maintenance situations (semi trucks / heavy equipment etc where downtime means $ lost)
It did appear some oil is getting past the OEM RTV on the RMS plate. I'll pull the plate, install the new seal in the plate using the install tool, then work it over the crank when I go to install the plate.
Oh that throwout bearing?
Wish you could hear this picture. "Clack Clack Clack" - honestly surprised this thing didn't come apart.
That doesn't look good.
Yeah - I'm glad I decided to tear into this thing regardless.
Time to get the pilot bearing out. This wasn't in the best shape either. No worries, I just spent a few days cleaning / organizing the shop so I could find all the tools / stuff I need without a lot of drama. Grabbed my bearing puller - went to flip the jaws around and turns out one of the narrow jaws (the size I need to fit in the pilot bearing) is broken off. I don't remember that. Lovely. Okay plan B. I ran across a spare clutch alignment tool, so I cut the loop end of it off, then went in the house and got a hot dog bun.
Pack the bearing cavity with bread, hammer the tool, pack it again, rinse repeat until
Got the RMS plate out, cleaned it up, installed the new seal, RTV - installed. Got the new flywheel installed and torqued.
I must be the only one who spends time cleaning up threads?
New clutch / pressure plate installed
New clutch fork, pivot ball, throwout bearing installed - everything greased up and trans is ready to go back in.
Here's where it got fun. Using an engine support bar to support the engine and drop the K Member is one thing. But doing that when the transmission is out adds another dimension. So lining everything back up for install involved using the floor jack / wood on the oil pan, engine support bar and trans jack. After a game of Jenga / Tetris - got it lined up - left the trans in 5th gear so I could move the output shaft to line the splines up if needed - one little turn and it slid together so easy I thought something broke LOL
Got a couple of bellhousing bolts in, got the trans in place and bolted up the trans mount so it would help support everything.
After some work with a torch and a long piece of pipe and a hammer - I tweaked the header just enough so it looks like the trans will clear coming out without too much drama. Then with new Ford OEM exhaust gaskets, new header bolts (flange bolts with hex heads so I can use an open end wrench if needed) started installing the header.
Ended up needing to rethread / clean up a few threads in the exhaust bolt holds in the head.
Turns out metal has a memory. So it was trial and error to see which bolts needed to be installed first to hang the header to it would all line up. When I got frustrated, walked away, did something else, and started again. One of those things was getting the old crusty exhaust bolts out of the bolt on collectors. Impact and heat got all but one.
The Bassani setup is that there are welded nuts on the header collector and their bolt on collector extensions use a sort of stud arrangement to bolt to this. Got new bolts / washers, but the one stud that broke? Even after welding a nut onto it - it wouldn't come off and ended up breaking off inside the nut. This was on the LH header that was still installed -so not a lot of room. Ended up using a combo of a Dremel metal cut off wheel, grinding wheel and a chisel to get that nut loose from the header, grinded the welded smooth and I'll use a new bolt / nuts / washers.
Finally got the header installed
Got the starter installed, motor mount bolted back up and started the K member install.
I don't recommend anyone doing this by themselves - especially if the trans was out too. Got the K member lined up with the trans jack, and it bottomed out on the motor mount studs. Ended up realizing the entire engine needed to come up. So using the engine support bar to bring the engine up slowly, then check clearance, back and forth, got it all lined up and bolted in.
Then it was just cleaning up hardware / old loctite etc and getting the front suspension back together. Forgot again to order the MM spring install tool. Prybar and dead blow to the rescue.
Got that all wrapped up, retaped routed some of the O2 harness. Dropped the trans off the mount to get the top two bellhousing bolts - and surprisingly they went in and even lined up with the metal O2 harness bracket. But I did sacrifice a wobbly socket to the cause. I used a piece of paper shop towel to hold the bolt so I could get it started, since I can't get my hand up there, and it worked great. Too great. The fit was so tight when I tried to work the socket off the bolt, the extensions came out but the socket stayed.
Oh well. Maybe I'll get lucky and it will fall out in the shop. Got the driveshaft in, got the exhaust bolts up with new hardware, fluid back in the trans / shifter etc. Got the clutch cable installed, adjusted the firewall adjuster all the way in, adjust the cable itself at the fork...Did a once over and fired it up.
Starter made a weird noise NOT a grinding - and it started immediately. But I'm guessing the OEM starter didn't like being disturbed after 20 years. Replacement on the way. Exhaust appears good to. Clutch engages good etc. No fluid leaks so far.
Took a quick test drive - holy crap - the clutch has never been this easy and smooth. I almost feel like I installed a hydraulic setup LOL.
Reactions: gkomo
Still working on the '04.
On the plus side, K-Member drop aside, the clutch works better than it ever has. But the other day, after getting to me destination, I walked around the front of the car and could JUST barely smell coolant. No leaks, no drips. Just the smell of coolant cooking off. Checked under the hood didn't see anything.
Went about my day, car running fine. The next morning, went to back out of the shop to go to work, and see a puddle of something under the car. FWIW this car is NOT a leaker. The night prior I had the front end of the car jacked up to check something, then let it back down.
It's not oil, and on the shop floor it was hard to tell exactly what it was. Cleaned it up, drove my wife's car to work, came home, nothing under the Mustang. Nothing leaking. It wasn't AC condensation (freon is low - I have a slow leak and don't use the AC hardly at all so I've put off messing with it).
While I had the car apart during the clutch / K member drop I was a bit aggravated by how old / worn the front suspension looks when I replaced most of it a few years ago. That plus realizing one of the new calipers I installed back in '23 is sticking - I finally decided to bite the bullet and do the 13" Cobra brake upgrade.
Parts roll in and so I put the car up on jack stands in preparation for stripping everything out. Come out the next morning to start tearing it down, and it's leaking again. Able to pin it down as coolant. And the expansion tank is down a bit. End up having to buy another pressure tester (long story - mine died) and finally found one that actually comes with the right adapter for the Mustang's expansion tank.
Hook it up, go up to 13psi or so and it starts to piss coolant out of the rear of the engine. NOTHING visible up top. Heater / coolant connection all dry. Crawl under, I can see where it's coming out of the bottom of the bellhousing and the RH side of the engine / bellhousing. I JUST replace the OEM plastic intake back in February - should be pics earlier in this thread - even with the Ford "updated" design the alum coolant crossover, sandwiched in between plastic, the plastic had started to fail and was cooking off coolant only when warm - under pressure. Replaced it with the "new and improved" Summit Racing / Ford Performance intake (it's the same exact intake, down to hardware and instructions). AFAIK it's been fine ever since.
Figured it had to be the metal heater return pipe that runs in the valley under the intake. NO SIGN of a leak at the back of the engine, so I was assuming the o-rings in the nipple / tube that's driven in the block behind the water pump OR a part of the metal line was leaking into the valley when it gets up to temp. Jacking it up in front, allows this coolant to run out of the valley / weep hole in the valley and over the back of the engine it comes.
So I order up the parts to replace that metal tube. Ford part is non-existent. Dorman makes one less than $30. Ordered that and a new nipple / tube with o-rings from Ford (like $10). Pull the intake. Pull the metal return tube, which is super fun BTW with a stud holding it in place behind the LH cylinder head. The Dorman part looks identical and the Ford part did have a bunch of corrosion. Replaced the tube behind the water pump, tried to install the Dorman part, but it just won't go. Get it lined up to bolt in and it pulls it crooked where it seats on the tube in the block. Finally cut it off on the straight part and run heater hose out the back to a metal union to meet up with the new Motorcraft molded hose I put on back in Feb.
This is mocking it up. The new design intake has even more room than the OEM (shorter runners) to run this pipe, so in hindsight, I didn't need to do all this - but it is what it is. I added clamps, sectioned it in the OEM heater line in back. Reinstalled the intake, hooked up water pump, all the coolant lines, added distilled water and pressure tested it.
Still pisses coolant out. Nothing in back is leaking. Finally able to see that coolant is spraying out into the valley, only under pressure - only once it gets up to 13psi or so, and it's running out the weep hole / back of the valley - again easily noticeable now because the front of the car is up on jack stands. Drain the water, pull the intake. The heater return line I rigged up? Dry. No sign of leakage. Only place it could be coming from is underneath the intake where the coolant block off is (LH Rear of intake). This new design uses pre-installed o-ring gaskets and they don't exactly seem all that robust. After a bunch of research, I decide to bite the bullet and find a place that has the all aluminum Speedmaster intake in stock. Should be here Thursday. With the intake off, I can't find any sign of a crack - that my eyes can detect anyway - and with no real way to pressure test it off the car.....
Remember this was in the midst of doing the Cobra brake upgrade, cleaning / painting / tidying up etc. So finally got back to that.
I was able to piece together the Cobra brakes cheaper than any of the kits. The calipers are new castings w/ brackets. I took them apart to paint them. New hubs - OEM hubs are 20+ years old and tired. New rotors + pads. Also plan on adding urethan spring isolators to the BMR front and rear springs I installed back in '23. I could use a tick more ground clearance+ my OEM isolators were toast.
Cleaned painted the knuckles, shields, control arms (replaced those in '23 - OEM bushings were shot) and even cleaned / painted the struts I installed back in '23 as well. Also pulled the fender liners and cleaned / treated those. Can't believe how much crud I vacuumed out of the side skirt where it's held in by the wheel well / fender liner. Going to also replace the LH Lower door hinge while I have the liner out - I can easily get to all the bolts without having to yank the fender itself.
Reactions: gkomo
To update
Got the Speedmaster intake in and installed. Ended up having to dig up my OEM hardware (fuel rail / coils etc) as the "improved" intake had its own and the Speedmaster appears to the original mounting bosses more closely than the plastic 'redesign'. Good thing I don't throw most hardware away.
Got the intake mounted, running Fel Pro intake gaskets dry as recommended by Fel Pro.
Got the intake installed, torqued, ended up running a heater hose from the nipple that feeds the heater return in the block behind the water pump to the heater core. No metal pipe needed. Got all the cooling hoses installed, filled with distilled water and hooked up the pressure tester.
16psi held for 20+ minutes. No more coolant flowing out. I DID however find a VERY slight leak from the radiator. And I mean SLIGHT. Not even enough to really drop the pressure. Seems to coming out where the plastic tank meets the alum core on the OEM radiator. Could also be where fluid was splashed around with all the testing / filling / draining. Will keep an eye on it and since I have UV dye in the system, should be easy to spot once it's up and running. If so, I'll replace the radiator.
So in essence it WAS the new intake leaking - the one I installed back in Feb. If I have time I might try to find a way to pressure test this thing off the car to see EXACTLY where it was leaking from.
Took the time while everything was apart to rebuild the OEM fuel injectors. New o-rings, spacers and filter baskets. Got the fuel rail buttoned up.
Got it all back together. In a hurry, not paying attention, and managed to overtighten a coil bolt and crack the ear on a coil. Ordered a replacement.
Drained the distilled water, filled with the 50/50 mix I drained out of it initially. (New in Feb). Primed the pump, checked for fuel leaks, good to go. Fired it up - and HOLY CRAP it sounds like a diesel race car. It was immediately evident I had a massive exhaust leak that wasn't present before all this. along with a miss from the broken coil.
Turns out the OEM EGR tube got tweaked just enough during intake removal / reinstall / test / removal etc - that it cracked down low where it goes to the LH header. I lucked out and was able to soak it with penetrant, and fish my 27mm wrench in between the K member and the body and it came loose. Removed from EGR valve, fished it out and yup. Crack.
It's obviously been tweaked, likely with header install etc over the years. Was able to score a new one from a local parts place for @ $50. Got it fished in and installed last night. Talking about TIGHT. I was able to snake TWO fingers just far enough to press down on the nut on the new pipe where it threads onto the header and GENTLY use the 27mm wrench to try and get it to thread on. Did I mention it's so tight I could only get mayb 1/8 turn on the nut before having to flip the wrench and move it. Rinse, repeat, rinse, repeat. It finally seated and threaded on.
Had to tweak it a bit up top, loosening the EGR valve from the plenum to give it slack, threading it in the valve, then tightening up the valve. It tightened down to the plenum - but odds I'm going to have clean up / re tap one EGR valve bolt hole in that plenum next time I take it apart. Fired it up just to make sure no leak. Then hooked up the DPFE valve / hoses / bracket / harness. Fired right up. Loping like it has a nasty cam. Unplugged the cracked coil - no change. So yeah, I'm waiting on a coil. Hopefully that concludes the unplanned engine rehab portion of the program.
All that's left now is get the rear up in the air, bleed the brakes, and install isolators on the rear springs. Hopefully.
Reactions: gkomo and squeak93
To catch this one up. The loping was a massive vacuum leak. Turns out there is a drilled / tapped screw on this intake that is unused on my '04. It's literally right under where the throttle linkage connects to the throttle body. After that, got it back together and it ran well. Then after about 30min of driving or so, it would throw P0171 / P0174 (Bank 1 / 2 lean). Not a major vacuum leak like the first, but bad enough. Idle would hang etc - typical vacuum leak. So since my smoke machine is MIA - bought a cheap one of Amazon - 10 minutes later. Found few small leaks and big one.
From the new intake.
This one is on me. The Speedmaster's lower plenum / runners are removable - two pieces bolt to the base intake, meaning two sets of bolts / two gaskets. I didn't check any of this before installing. On me.
A few of these bolts weren't exactly torqued down. Ended up reusing the gaskets and spreading RTV on both sides of each piece where they mate up. Torqued it all down.
Also upgraded the 'normal' Fel Pro intake gaskets to these Steel backed Fel Pro gaskets. They have torque limiters and even spec to torque the intake down to 22 ft/lbs - more than the OEM 18 ft/lbs.
Torqued it down, put everything back together, fired it up - even after sitting overnight with no battery connection / so no leaned fuel trim / tables, it fired right up, idled rock solid cold at @ 1200rpm. Fed it coolant, and went for a ride. It was still learning, but no codes, no hanging / high idle.
Cobra brakes are WELL worth the upgrade. While my wheel bearings weren't loose or showing any signs other than being 22 years old, with the new wheel bearings, the car is scary quiet / smooth on the interstate at 70mph +
I didn't get the intake for any perceived HP gains. Simply didn't want to ever have to deal with plastic + Coolant. Placebo effect is real, but car pulls hard. Might even stop being lazy and take it to a local guy who had a dyno and has done some tuning for me in the past and see what he can do with it. Granted I don't care about dyno numbers. It's a 4.6 2v. I want usable power / torque under the curve, where I drive it everyday. He has delivered that in the past so we'll see.
New clutch - still getting used to it being so easy to use.
Also got the lower door hinge replaced while the fender liners were out. After WAY too much time trying adjust it, I finally loosened the BOTH hinges (top hinge wasn't touched) and kind of let the door 'settle' where it wanted to be. Not only do the door stops work, the door is adjusted to where a slight push on it from the first stop and it shuts and latches with almost no effect. Works for me.
