as for bending, it's just the bracket that is bending not the rail. It might have lost it's mojo but it really seems like something else is going with fuel pressure not relieving to me b/c it's not happening when driving - all 3 times we found the leak was in the garage after driving it and it sits.
I see what you are saying. Once that metal starts bending, it does weaken. Mine is more of a 90 degree Z-bend there, so from your pic it does look like the rail is already compromised.
47 psi (the max you saw) inside the rail equals about 8 lbf at each injector of upwards force assuming a 0.180" opening into the injector.
Took a peek on Ebay and was surprised to see how few 4.6L fuel rails there were. I did see a couple at $100-150.
I've got one in my inventory but would prefer not to separate it from the manifold, typically people want them together... These cars are getting older so finding a perfect one is tough and they sell for a premium from what they did that's a fact: https://ebay.io/m/8DyQCG
I'd offer $89.99 and let him counter his bottom line, not easy to sell either right now...
so i can't get this analog gauge to read any fuel pressure. I took the core out of the valve and it didn't help. The gauge DOES work on my chevy just fine. So something is not happy about this ford adapter that came with it. I'm going to see if I can borrow a ford style gauge at work tomorrow (one without an adapter) Very perplexing why it reads nothing. I may also pick up a rail over the weekend if they still have it.
I warned you it was a special order .... ONLY FORD!!!... It won't be any different than the the sensor OBD reading unless the sensor is bad, face it that isn't the issue because it was DEAD SPOT ON....
That's the point. If the sensor is bad, then it would cut off fuel at the wrong point (high or low). The ECU wouldn't know the difference, it can only act on what it's told.
100% agree.... My point was over the adapter issue, it is a VERY special order adapter.... Sadly....Kinda' like the 3V old style plugs for compression, except finally some caught on if it's DELUXE hahahaha ....
do you have a link to the Ford adapter so I can order? - i tried another gauge at work that had the 'adapter' in the box and no luck.
i drove it 25 mins this morning and watched the fuel pressure when I could glance at it - it stayed from 37-42 the whole drive. Doesn't this confirm the FRPS is fine?
