3G Alternator install question
Hello everyone,
I am installing a 3G (PA performance conversion) in my 78 King Cobra. I don't want to butcher it too much.
There is a green wire from the back of the 3g alternator, where is everyone wiring the green wire into.
Supposed to be a 12v switched source it looks like.
Additionally, there is a white choke wire. Does this splice into the white alternator wire and plug into the back of the alternator?
Can I remove the entire harness that connects to the original alternator?
I have been searching threads but for some reason my head is spinning on the procedure.
I believe i have thought myself into a circle of doom. haaa
I would really appreciate any recommendations.
Thank you very much.
Reactions: DadLife0724
You've probably already run across my short thread, but here's what I had to share about it:
All I did was follow the instructions that came with the kit. Obviously, the heavy gauge goes to the battery, then one wire attaches to the positive lead on the alternator, one lead attaches to another point on the alternator, and the last lead attaches to one wire in the original harness. Then you replace the regulator with the new one, which is supposed to do whatever voodoo it does so the ammeter works like it's supposed to. At least that's how I understood it. You'll need this kit:
Their instructions are provided in a link toward the bottom of the page.
I can take a look at my car tomorrow to see if I can help a little more.
Something that I'll add that I didn't mention in that thread is that the V belt pulley didn't have enough contact with the belt to turn the alternator reliably, so I got a lot of squealing. I ended up going with a serpentine style and the problem went away. Just something to keep in mind....
thank you very much for your reply. Did you happen to try the 289 Hipo V-Belt Pulley before doing the Serpentine swap?
Trying to avoid the serpentine swap since i have the Power steering, AC etc...
No I didn't as I didn't have one. Figured my situation didn't really need to keep with a V belt so the thought barely crossed my mind. I did know that I saw some article, I think it was Hot Rod, where they swapped a 3G into something like a Fairlane and used the double V pulley on the alternator though.
Hello everyone,
I have the green wire spliced to the orange wire coming from the original alternator connection. The white wire from the original connector isn't hooked up to anything. the white wire from the 3G connector goes to the stator connector on the back of the alternator as indicated in the directions that are linked in my quote in my first response. That all should get you wired up! :nice:
