Progress Thread Deals are still out there.
I got my Amazon air gap.intake and it looks pretty good. Im going to clean up the casting flash and install it. I primed my motor and found thebplug on the rear china wall starting to seep. I used aircraft sealant and sunk it down to were I thought it should go. Any suggestions?
Reactions: General karthief
I installed another plug and primed it and it leaked as well. I Finally got the third plug to seal. I used a 3m scotch bright to rough the edge of the plug to rough up and used a liberal amount of this retaining compound. Let it set for 24 hours. Hit it with the prime tool, no leak. Not ashamed to admit i used Gemini to trouble shoot this. How many of you guys use this tool for specs or quick technical questions?
I had ordered an Amazon air gap intake and it looked pretty good. I started cleaning up the flashing. The one issue i have is the rear runner port is not square. I squared it up best i could.
My buddy at work had a megasquirt ms1 v2.2 with holly throttle body. The harness was hacked up and missing few of the vital circuits. So I ordered a few sensors and a tune cable and ill try my hand at trying to get it up and running.
On my fist attempt to access the ms1 it would not communicate. Long story short v ref was at 2.6 volts so I had something taking down the voltage. Disconnected the main harness and jumped power and ground and the unit started communicating and I was able to start making adjustments to the software. So the main harness that is all hacked up has a short in it. Now I get to build a harness and go from there .
Looks familiar, other than missing the "ProComp" branding on the runner.
Are you thinking of cutting the plenum divider as well?
Reactions: mattcrp1
I blended the divider and smoothed it out some. the tbi adapter has it standing off the mounting surface some.
Reactions: LILCBRA
I kind of have of set that way. I am running out of hood clearance. The tbi is shorter but the air gap stands up more than a regular manifold.
Reactions: LILCBRA
