S sheets55 New Member Apr 2, 2007 2 0 0 Apr 2, 2007 #1 Apr 2, 2007 #1 Installing 2000 8.8 in 82 gt need info on backspacing of rims and what size that will fit this application ---------Thanks a lot!------------sheets55
8 86bluecobra Advanced Member Dec 20, 2004 4,265 12 69 B.C. Canada Apr 2, 2007 #2 Apr 2, 2007 #2 As long as the 2000 8.8 is the same length as the 86-93 8.8's then the tire of choice would be a 15x8 inch with a 5.5 inch backspace.
S sheets55 New Member Apr 2, 2007 2 0 0 Apr 2, 2007 #3 Apr 2, 2007 #3 thanks 86 , It is 3.25 inches wider ,thought some of you guys have done the swap, any one else?------------------sheets
Roland69 Sergeant Tangnet Sep 17, 2005 2,867 3 58 Port Elgin, Ontario Apr 2, 2007 #4 Apr 2, 2007 #4 http://mjbobbitt.home.comcast.net/mustang/5lug.html
Shakerhood 20+ Year Stangneter Oct 28, 2004 3,360 211 114 Ohio Apr 2, 2007 #5 Apr 2, 2007 #5 I would try to stick with a 94-98 Axle Assembly as it is wider than Stock but not too wide to create Wheel and Tire Issues that the 2000 will cause you.
8 86bluecobra Advanced Member Dec 20, 2004 4,265 12 69 B.C. Canada Apr 2, 2007 #6 Apr 2, 2007 #6 sheets55 said: thanks 86 , It is 3.25 inches wider ,thought some of you guys have done the swap, any one else?------------------sheets Click to expand... sorry mate.
donsbad68 Immensely Educated Jan 4, 2003 838 0 0 Oklahoma Apr 3, 2007 #7 Apr 3, 2007 #7 1999 and newer axles cause major wheel and tire issues. You will need close to a 7 inch b.s. good luck on finding wheels
