Well here's what the newer Bullitts look like...
The backspacing is a little different from the other years at 6.29". That meant I needed a 1.5" bolt on spacer up front.
I ended up using a 1.25" spacer in the back but things could've worked with a 1". I used the 1.25" to try and balance things with the front as far as width and all...
BTW, it's a '69 Mach 1's 9" rear. Standard but fresh springs and suspension.
