05 Convertible Electric Issues
Skynard05
hey, I bought an 05 mustang and the instrument cluster has no power nor will the top come up or down . Is this two separate issues or could the problem fix both, didn't know if they get power from the same source
i would start checking grounds i had a f150 lose power to all sorts of stuff the grounds were all crimped together in main harness and they broke off the single ground wire feeding them...easy fix...was a bear to find
Reactions: Skynard05
The radio, power windows, power locks, ac controls , interior lights, headlights,tail lights all work it seems like whatever sends power to or controls the dash lights and convertible top isn't working and I don't know what that is ... ☹️
Not real familiar with 05's but if you post your question in the 05-2014 specific tech forums you'll get some advice.
Personally I'd start with the fuse box, or the power distribution box.
i do know on the positive side of convertible top will be on its own circuit and cluster also likely both wouldnt lose two separate positive circuits but a shared ground likely im no expert just my personal experience with car electronics
Welcome to stangnet.
Like Karthief said, post in the '05-'14 tech section. You'll get hold of the people that can help you there.
Good luck brother.
It's good to have you with us.
