10.5" rear wheels on '90 GT?
HaynStang
124
Portland
Looking at some 10.5" wide rear wheels with 27mm offset... What needs to be done to make them fit? What range of tire sizes would I be able to run? I'm converting to 5 lug, obviously I'll have to keep the stock track width with these wheels...
Fox length axles are a MUST! If you don't have the stock length they will stick out of the wheel wells considerably. SN95 axles are 3/4" longer than the foxs' are so don't do it that way with 10.5". You also must remove your quad shocks, and bang in the frame rail. I would also recommend rolling your quarter wells because 10.5" wheels on fox axles will be even with the outer edge.
