  • 1994 - 1995 Specific Tech
10 Second sn95 ?
  • Thread starter Thread starter SHOJOE
  • Start date Start date Dec 11, 2008
SHOJOE
20
Maryland
Dec 11, 2008
  • Dec 11, 2008
My name is Joe, I live in Maryland and am 20 years old. I am on a quest for 10's in an sn95. At the moment I dont even have a mustang I drive a SHO. In the past I had two mustangs a 1995 GT and a 1985 5.0 (really miss those cars). I am going to build a strip sn95 looking for mid 10's and want everyones point of view on whether you think my setup would get me there. And what I should do and not do. I am not the richest kid (work at pepboys), but I have patience for the build. This is something I really have been longing for. This is just some of the things I had in mind to get on track.
Chasis
v6 sn95 chasis
UPR Front end k-member kit
UPR Rear End kit Anti roll, ALCA's, AUCA's, torque boxes etc
Moser 31 spline 8.8 spool kit with axles, spool, c-clip eliminators
UPR Full length subframe connectors
Manuel steering rack
GT Rear Springs (airbag in right rear)
Aluminum Driveshaft
Solid Motor mounts
Full roll cage
4.10 or 4.30's (in rear end?)
Lakewood 90/10 Front
Lakewood 50/50 rear
Engine
351W .030 over
Rebuilt bottom end built to factory specs except forged pistons
AFR 185 heads Or TFS
Edelbrock Vic Jr Intake (I want carbed!)
Holley 750 Carb
BBK L/T's
1.6 Scorpion RR's
Jay Allen Custom Grind Cam
Nitrous 100 first stage and 200 second stage
Redneck Racing c4 tranny
I need help on my fuel system not to sure what regulators and pumps I should look in to.
Yobi1Kanobi
559
  • Dec 11, 2008
If its just going to be a strip car with a 351 based motor. Why not go Carb
Zero Signal
2,633
Tucson, AZ
Dec 11, 2008
  • Dec 11, 2008
I'm wondering about the 'factory spec' bottom end. I'm thinking you'll need 500+hp to get in that range, but I'd imagine that would be pushing a stock bottom end too far, even with forged pistons.
BTW, he DID mention he's going carb.
SHOJOE
20
Maryland
Dec 11, 2008
  • Dec 11, 2008
I see alot of stock bottom end 302's going 10's. I chose the 351 route becasue of the added rigidness of the block and the added cubes. I am going carb'd
BlackVert
5,589
9
98
Bethesda, MD
Dec 11, 2008
  • Dec 11, 2008
by bottom end "factory specs" are you saying you would be staying at 351 and about 9:1 compression?
seems to me that stroking it to 393 or 408 would get you there alot more easily, epsecially if you are staying NA
also, you might consider pro magnum rockers because they fit under stock height valve covers, which might help with the fitment of the intake and carb and stuff like that
lastly, if you are using hydraulic lifters but you get a block that was not made for hydraulic lifters, you will need to add link bar lifters to your list of things to get. i'm not sure if that holds true for solid roller lifters or not.
i actually have a motor that would be a great start for you, and i'm in maryland too, but i hear you about the finances thing, and it is probably out of reach for you at this time. i also have a 750 carb and a rpm air gap intake and some other carb stuff for it because i was going to go carbed at one point
i'm selling my engine (and car) to finance the restoration of my 67 fairlane
Yobi1Kanobi
559
  • Dec 11, 2008
nevermind read too fast....Anyways yeah I wond probably go with more compression and like a stroker
Venom351R
4,548
41
98
MAINE
Dec 11, 2008
  • Dec 11, 2008
Are you going the Nitrous route just b/c of the cost factor compared to boost?
Killercanary
The car that set the bar.
Altoona, PA
Dec 11, 2008
  • Dec 11, 2008
I don't see a reason it wouldn't go WAY into the 10's with the spray on it. I'd expect it to be a mid-high 120mph car NA if you kept the weight down as it appears you will. With the squeeze on it, it should trap in the 130mph range if setup correctly.
I'd personally go with an AFR 205 at a minimum and an Ed Curtis cam, but that's me.
Is the car in your sig your old one? if so, what did it run? I see it had skinnies on it so I assume you had it to the track.
M
moostangvert
47
  • Dec 12, 2008
dead on agree. if i went through the trouble of putting in a 351 based engine, id go to 408 personally. 10's wouldnt be a a problem with a 408 on 200 shot. my buddy omar went 10.80's with a 357 and 100 shot.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Dec 12, 2008
#10
  • Dec 12, 2008
  • #10
Look up yellow94GT on corral. His 347 runs high 10's n/a on 18" drag radials. 466rwhp.
sage2k
645
Baton Rouge, LA
Dec 12, 2008
#11
  • Dec 12, 2008
  • #11
cheapest thing to do is buy a car that is already partly modded!
SHOJOE
20
Maryland
Dec 14, 2008
#12
  • Dec 14, 2008
  • #12
-Some guy just offered me a 1987 lx vert with a 331 stroker for my SHO. Sounds a bit to good to be true. I have not seen the car in person yet.
-My old 95' GT in my sig ran 12.9 on motor. Just a bolt on car with 4.10's.
F
fish254
237
Brooklyn NY
Dec 14, 2008
#13
  • Dec 14, 2008
  • #13
i would say 331 and some juice would be the cheapest way!!
R
red dragon95
50
north las vegas
Dec 15, 2008
#14
  • Dec 15, 2008
  • #14
a 351 will handle more poer than 500.i have a friend with a 95 lightning complete stock motor and a nice turbo and it lays 660 to the tires.he also has the 2000ish lightning and make a tad over 700 with a vortech on it.
SHOJOE
20
Maryland
Dec 16, 2008
#15
  • Dec 16, 2008
  • #15
Nice.
Yes, I am going the nitrous route instead of turbo because of the cost factor. Unless I am able to get my hands on a nice used single turbo setup.
L
lilhoppin95
39
huber heights,ohio
Dec 16, 2008
#16
  • Dec 16, 2008
  • #16
I went 10.89 with 347 and little d-1 procharger!Now in the 9s with F-2 and 408.The more you spend the faster you can go!!
M
moostangvert
47
#17
  • Dec 16, 2008
  • #17
aint that the truth!!!i got tired of spraying all the time plus refills get expensive!!! ive used a whole bottle on 1 hit!hahaha. the charger is nice, you dnot have to worry about anything (to a certain extent) but i got a small shot of gas on top
i had a 150 shot on my car. it was good for about 4 or so runs down the track keeping goood constant bottle pressure
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
