17x8 wheels up front??
I have American Racing Torq-Thrust II on my '65. I tried 17x8 with 4.75"BS and had interference with the upper control arm. I have Global West UCA's, so it could be an interference issue that's particular to the suspension. I wound up with 17x7 up front and 235/45R17 tires (I used the 17x8 4.75BS on the back without any issues).
For what it's worth, I ordered the wheels through a local tire dealer, and had them try the fit before mounting the tire. They were able to exchange the wrong wheels for the right ones with no fuss on my part. Might be worth thinking about.
I ran 16X7 with 4.5" offset in the front with the GW uppers and didn't have an interference problem unless I had the car at full lock one way or another. I had a bent travel stop that was the culprit (the one that bolts on the strut rod at the LCA). You could of got an 8" wheel in there easy.
Whatever you do, you need a shelby drop at a minimum or for maximum clearance you need either the GW arms or the PMS kit that lowers the arm 1 3/4". In stock form, the suspension gets positive camber gain on compression. Puts the tires right into the fenders. Not good.
People can argue weither or not you need the extra 3/4" of drop from a performance standpoint, but they can't argue the additional clearance you get from the camber gain!
I have 17x8's on a 66 coupe. I'm using an opentracker upper with the 1.75 arm drop. I'm using 225's on the front.
I have 1/4" between the rim and uca so 4.75bs is max with my setup. On the outside I have plenty of room with a 225. I'll run a 245-40-17 next time without an issue or a fender roll.
The only issue I had was at the front lower driver side fender. That area rubbed over a hard bump. I went in with a grinder and made that lip smaller. That lip was about an inch wide and I removed enough metal to make it look the same width as the rest of the fender lip.
As dodgestang will tell you this worked for ME and your results may be different. If you are unwilling to roll a fender or redo some paint, buy a 7" wide rim with 4.5 bs. Also use a tire 225 or less.
I was gonna chime in, but you 65/66 guys will feel sad if you knew how easy this was on 67-70s...so I won't tell you :D
I drew a stick figure with your name on it and I just finished urinating on it.......:D
You have no idea how long I spent trying to fit a 255 45 17 under the back of a 66 coupe. Whata pain in the ass. I'd like to travel back 40 years or so and kick someone in the balls.:rlaugh:
If the 255 45 17 was easy to get in there, you'd be mad that a 285 wouldn't fit!!!lol:) :)
LOL...well don't try to kick me I'm soaking wet already!
I have Globalwest suspension on the front with 17x8 and 245's with a rolled (badly) fender. I had to do some work on the upper arms to keep them out of the rims at the upper ball joint area. Also modified the steering stops to help. Rear have 17x9's with either 245 or 255's, and again badly rolled fenders with a baseball bat. Rims are Compomotive Cobra style, I can't remember the offset but 4.75" come to mind.
I was going to ask who has 275x17's on the rears? And how?
I have seen a few cars with them at the track and it looks like it could fit with just enough room to clear the leaf, but very hard to say. 17x10 exactly fit right would be needed with all going towards the in side (center) of the car. It also may be that they use the slightly narrow springs to get the meats on the car, but I didn't think to look...
Sandy
Im running Stock 2001 17x8's with 245/45's all the way around, no spacers. The front of the drivers fender rubs when backing out of my driveway, but thats it! I have wilwood discs in front ( 1/2") more track width, and a '67 9" rear(1" wider track each side). I did need to grind the uca's for clearance.
image.php
[/url][/IMG]
Hey deltascrew,
Do you have any pics of your setup? Also, what size tires are you running front and rear?
Thanks
225/45/17 front & 245/45/17 rear.
the pics aren't very good but here you go....click on pics to enlage
<a href="http://picasaweb.google.com/mustangbrantley/1965Fastback/photo#5150646922422586722"><img src="http://lh6.google.com/mustangbrantley/R3rGFi51DWI/AAAAAAAABE4/zW15unTVarU/s144/IMG_4098.jpg" /></a>
<a href="http://picasaweb.google.com/mustangbrantley/1965Fastback/photo#5150646630364810562"><img src="http://lh6.google.com/mustangbrantley/R3rF0i51DUI/AAAAAAAABEk/mx3m8kLJ7Zs/s144/IMG_4094.jpg" /></a>
<a href="http://picasaweb.google.com/mustangbrantley/1965Fastback/photo#5150647055566572914"><img src="http://lh5.google.com/mustangbrantley/R3rGNS51DXI/AAAAAAAABFA/-678Ehg6Rls/s144/IMG_4100.jpg" /></a>
