6 65JMustangGT350 New Member Mar 9, 2025 1 0 1 Indiana Mar 9, 2025 #1 Mar 9, 2025 #1 I am installing the comp cam retrofit dog bone. The holes I drilled don't exactly line up. The rear hole is to the left a bit. Am I screwed or can the dog bone be adjusted/bent? Thanks!
Noobz347 Stangnet Facilities Maint Tech... Er... Janitor Admin Dude Jan 4, 1985 43,552 21,722 234 Box behind Walmart Mar 9, 2025 #2 Mar 9, 2025 #2 Screwed? Sorta. It's going to cost you. https://www.summitracing.com/parts/HRS-91168 The alternative would be to take the block to a machine shop and have it corrected and drilled again.
