used the lincoln for years in construction ,metal stud work. used core wire.was able to easily pack it up scaffolding and get into tight places .loved itI use a Lincoln 140 Mig. Started off with a cheap offshore welder and did not like the quality so before I did any exterior panels I went and bought the Lincoln. Seems to do a much better job. I picked it up for just under $500.
i believe the lincoln 140 is 115 regular house current and the 180 is 220 if you have 220 outlet that is the one i would recamend but the 140 will workWould the Lincoln 140 Mig work on the frame rails as well?
Did someone buy them? I just found the same welder and parts available for the one I bought on line from multiple sources. Not that I have had anything break on it, but might get a replacement gun if they really are going out of business. I've almost melded it on many occasions..... Clarke mentioned above went belly-up a couple of years back.
not sure if tweeco makes a gun for it ,but i would go that way .you will not believe the difference. i think the guns are universal. it was a major improvement over the origional miller.i nearly returned my miller untill i changed to tweecoDid someone buy them? I just found the same welder and parts available for the one I bought on line from multiple sources. Not that I have had anything break on it, but might get a replacement gun if they really are going out of business. I've almost melded it on many occasions.
http://www.clarkeinternational.com/shop/categories/search/welders-accessories
Wow, looks like their back!Did someone buy them? I just found the same welder and parts available for the one I bought on line from multiple sources. Not that I have had anything break on it, but might get a replacement gun if they really are going out of business. I've almost melded it on many occasions.
not sure why but the weld is much smoother with no sputtering and less spatteringI stepped on the tip of my gun here while back, stripped the threads out of the end of it, bought a tweeco gun to replace it, and now I wish I had stepped on it years ago, works alot better now for some reason.
