1968 DOHC 4.6 Coupe Project
Really some great work!!! Nice eye for details and lines.
I assume you'll be running a fuel cell with the FI anyway but just in case you didn't notice that rear sway bar will prevent you from using the stock fuel tank.
I will be using the stock tank. I bought the second kit Rod & Custom made and they sent the wrong sway bar. Here is the correct one that is in front of the tank
We had a problem with the drivers door sticking out 1/4" at the bottom even after elongating the holes in the hinge. We cut 1/4" out of the bottom of the door.
Brian had to cut out a section to get at the inner brace to cut it. After the brace was welded he brushed some epoxy primer than welded back in the piece he cut out.
