Drivetrain 1978 Cobra Anyone Ever Install Performance Automatic Valve Body?
Vic1978
94
52
38
49
Anyone try the Performance Automotive PA26302 valve body?
I’ve been looking for a review by owner on a Mustang II or Cobra and I don’t see any.
I’m looking for a shift kit or valve body that is driveable under normal driving then chirp the tires when needed.
  • Sponsors(?)
LILCBRA
2,221
1,252
164
48
Marietta, Ga
I installed a restrictor plate or whatever it was way back in 1990 or 91, but at that time it was just an over the counter part at places like Advance Auto. What I used worked exactly as it sounds you are looking for. IIRC, it was a B&M shift improver kit or something along those lines and it was really simple to install. Here is a link to what I think I used, it's been forever so it could've been a different brand.....
https://www.summitracing.com/parts/bmm-50262/overview/
Vic1978
94
52
38
49
Thank you LILCBRA. I ended up buying the performance auto valve body Saturday, we’ll see how that works.
I’ll post it after the install.
Reactions: LILCBRA
Vic1978
94
52
38
49
I installed the valve body and I just get stiff shifts, nothing more. I believe the rear end has a gear ratio of 3.00, if the rear end wasn’t changed out throughout the years and from what I read, need a higher stall converter because of my cam.
Im sure that if I replace with better parts, I’ll get better performance out of it. One thing I don’t want to lose is more top end, right now, the top end is ok. Wish I had a fourth forward gear in the transmission.
LILCBRA
2,221
1,252
164
48
Marietta, Ga
That's really about all the valve body will do for you, so it sounds like it's working as advertised. As for another forward gear, you'd most likely need another transmission like an AOD. I think someone sold an add-on part or a lock-up converter or something that gives you another "gear" but I could be mistaken. I haven't run an automatic in my car for quite some time - like around 20 years - so I'm not up on everything there is to know about them any more. The closest I've come is an 84 convertible that I transplanted a 5.0/AOD/8.8 combo from a Lincoln Mark VII. I only ran the car for maybe 2 years before I had to sell it, but it was a fun little car! I left the transmission completely stock, only changed a seal or 2 because it was leaking all over the place. As for help on the top end, a quick and easy way to do that would be swap a taller tire, but you'll lose acceleration from the line that way. The opposite is true if you use a smaller diameter tire. It's all a trade off in that regard, same with swapping rear gears.
Thread starter Similar threads Forum Replies Date
L 1978 king cobra center wheel hub 1974 - 1978 Mustang II Talk & Tech 3
L 1978 wheel cap Cobra picture 1974 - 1978 Mustang II Talk & Tech 0
colorado cobra Interior and Upholstery 1978 King Cobra missing radio delete panel 1974 - 1978 Mustang II Talk & Tech 6
colorado cobra Engine 1978 King Cobra Engine Seized From Sitting 25yrs. 1974 - 1978 Mustang II Talk & Tech 15
9 For Sale NOS 1978 King Cobra Wheel Mustang II Parts 6
Vic1978 1978 Cobra Vacuum Ported Switch Question 1974 - 1978 Mustang II Talk & Tech 3
Vic1978 1978 Cobra Smog Tube Help 1974 - 1978 Mustang II Talk & Tech 3
R For Sale Pair Of Tailights From 1978 King Cobra Mustang II Parts 0
Vic1978 Build Thread 1978 King Cobra Build 1974 - 1978 Mustang II Talk & Tech 66
Vic1978 Found Need Dash Pad 1978 Cobra Mustang II Parts 3
Vic1978 1978 Cobra Engine Harness Routing Help 1974 - 1978 Mustang II Talk & Tech 6
5 Cl Find 1978 Mustang Ii King Cobra - $3400 (pensacola) 1974 - 1978 Mustang II Talk & Tech 0
V Value Of 1978 King Cobra 1974 - 1978 Mustang II Talk & Tech 4
W For Sale 1978 Cobra Mustang Ii, 4 Speed 302. Grand Rapids, Michigan Mustang II Parts 4
kcobra302 Expired 1978 king cobra Other Classifieds 0
Jordan Carry 1978 King Cobra Mustang II restoration 1974 - 1978 Mustang II Talk & Tech 6
CarMichael Angelo 1978 Fairmont Build: Chapter 6. Chapter 6. VICTORY! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 214
S WTB/Trade 1978 Mustang2 parts Mustang II Parts 0
G flexplate needed for a 1978 mustang ii (5L V8) 1974 - 1978 Mustang II Talk & Tech 2
DIVER900 For Sale 1978 2.8L v6 power steering pump Mustang II Parts 0
G 1978 mustang ll motor mount 1974 - 1978 Mustang II Talk & Tech 2
A 1978 302 Serpentine conversion 1974 - 1978 Mustang II Talk & Tech 3
7 78 sport package ghia rarity 1974 - 1978 Mustang II Talk & Tech 12
D Plug gap for 1978 302 in '67 Mustang? 1965 - 1973 Classic Mustangs -General/Talk- 6
R Headers for a 1978 Mach 1? 1974 - 1978 Mustang II Talk & Tech 5
K 1978 engine swap v6 to??? 1974 - 1978 Mustang II Talk & Tech 9
3 New Member: 1978 M II Mach I 1974 - 1978 Mustang II Talk & Tech 12
C 1978 MUSTANG II V6 Swap 1974 - 1978 Mustang II Talk & Tech 11
F 1978 rear end swap 1974 - 1978 Mustang II Talk & Tech 5
N Building a Daily Driver 1977 1978 V8 Auto 1974 - 1978 Mustang II Talk & Tech 4
colorado cobra Suspension 1978- Manual vs. Power Outer Tie Rods 1974 - 1978 Mustang II Talk & Tech 2
N 1978 Mustang Will a chevy 305 fit in it 1974 - 1978 Mustang II Talk & Tech 13
S Wheels-Tires 1978 5 lug disc brake upgrade and looking to fit 17 inch wheels 1974 - 1978 Mustang II Talk & Tech 0
D New Guys 1978 Coupe The Welcome Wagon 1
T trying to use 1979 clutch facing and pressure plate on 1978 flywheel 1974 - 1978 Mustang II Talk & Tech 17
Vic1978 WTB/Trade 1978 Mustang 302 Headers Mustang II Parts 1
Vic1978 WTB/Trade Need A Fan Shroud 1978 302 Mustang II Parts 1
78ttop For Sale 1978 Mustang Ii T-top Fastback For Sale Mustang II Parts 1
P 1978 302 Mustang Ii Clutch 1974 - 1978 Mustang II Talk & Tech 10
G Expired 1978 Mustang Ii Fastback For Sale Mustang II Parts 0
V 1978 Mustang Ii Smog Removal 1974 - 1978 Mustang II Talk & Tech 3
rusty428cj Build Thread 1978 Mustang I I 1974 - 1978 Mustang II Talk & Tech 128
M Expired 1976-1978 Lincoln Versailes Disc Brake Rearend For Early Mustang Swap Drivetrain Parts 1
L Free Parts From My 1978 Coupe 1974 - 1978 Mustang II Talk & Tech 0
7 1978 Ford Mustang II T-Tops for sale Mustang II Parts 1
B 5.0 into 1978 Mustang Help 1974 - 1978 Mustang II Talk & Tech 3
D V-8 Mach 1 1978 parts for conversions Mustang II Parts 0
K Looking for my father's '65 convertible, sold in 1978 1965 - 1973 Classic Mustangs -General/Talk- 3
Bmwz389 1978 Mustang II Coupe for sale Mustang II Parts 2
Bmwz389 1978 4 Cyl Hard to Stay Running. 1974 - 1978 Mustang II Talk & Tech 3
