- Aug 15, 2002
- 317
- 0
- 0
My buddy gave me his old brake setup off his 88GT because he just finished his 5lug cobra brake setup. I got his old spindles and front brakes, can I use my 86 struts? or do I have to buy new ones?
fordnatic said:your struts will work... all 85-93 5.0 stangs ran the same strut. However if they are in question you should change them while you have the front end torn down that far anyhow. my 2 cents
89MustangGX said:I believe you can in fact use your old struts, but you will need washers or steel spacer plates to make up the difference in width at the bottom. The top should be the same. Some struts actually come with these as they're designed to be used for the different years.
If this is confusing, I have a set of spacer plates off a pair of struts I took off, I can take pics.
1986LX2002 said:I have Koni red adjustables, so where do you put the washers/spacers?
BlackFox5.0 said:Where the strut makes contact with the spindle.....you need washers so the bolts don't crush the strut.
