1988 Check Engine, Gas, Washer Fluid, etc. Lights
  • Thread starter Thread starter RedVert88
  • Start date Start date Jan 30, 2012
RedVert88
  • Jan 30, 2012
I have a question about the lights on the lower right hand side of my cluster bezel. I bought the car in July of 2011, and I always knew that those lights didn't work. However, the yesterday I was replacing the dimmer switch, and while everything was torn apart, I noticed that the entire check engine, gas, washer, etc. unit was not there. It's not that the bulbs were out or something. There is just nothing behind the lenses.
So my question is what does this thing look like? Was that ever a factory delete option, lol?
Also, I have no buzzer/chime like when the lights are on and the door is open. Are these things related?
Thanks!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 30, 2012
  • Jan 30, 2012
The part you mentioned is part of the GT option package. There is a small flexible plastic sheet that acts as a circuit board for the wiring and light sockets. It overlays the standard plastic circuit sheet and makes contact with body wiring connector. There is a white plastic holder for the light bulbs that the flexible plastic circuit sheet connects to.
The chime loses its voice over time and will get so faint that you can no longer hear it. I don't have a fix for that at this time.
Blown88GT
2,283
524
164
Palm Beach Gardens, FL
Jan 30, 2012
  • Jan 30, 2012
'88's, even GT's, don't have the CEL.
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Jan 31, 2012
  • Jan 31, 2012
Except for 1988 California models with Mass Air
RedVert88
  • Jan 31, 2012
Thanks for the info. So, you have to have mass air to have a check engine light. Ford must have been pretty confident in their SD setups.
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Jan 31, 2012
  • Jan 31, 2012
You can pull the codes in any 86-88 Mustang just like the 89-93's. If has the same code-management system. Only difference is no light on the 86-88 cars.
So if there was a code stored, you would never know it unless you just randomly checked.
So guys with SD setups should routinely code check. I do in on my car every couple months or whenever something doesn't feel right.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 31, 2012
  • Jan 31, 2012
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
jdb3rd
166
edgewater MD
Feb 2, 2012
  • Feb 2, 2012
My 88 has a check engine light and so did my 87
ID89GT
1,659
18
49
Spokane Valley, WA
Feb 2, 2012
  • Feb 2, 2012
Those lights never worked in my 89 either. I had the bulbs and such for them, they just never turned on lol. The cluster I have right now is out of an 89 as well and it has the same thing. Ill find out if it works when I get around to my EFI swap..
Boydster
5 Year Member
Apr 10, 2011
301
20
39
Maryville, Tenn
Feb 2, 2012
#10
  • Feb 2, 2012
  • #10
Really? My 87 has a low coolant, low oil, lots of other lights, but no Check Engine Light, and especially not one associated with showing EEC codes.
Engine Information that is Needed When You Post a "Car is not Running" or "Car is Running Poorly" Thread
  • AeroCoupe
  • Apr 28, 2025
2K
Fox 5.0 Mustang Tech May 4, 2025
Bullitt347
Progress Thread 1993 LX Hatch Progress
  • Mac131
  • Aug 24, 2024
  • 9 10 11
15K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 15, 2026
Mac131
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
2K
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
Electrical Foxbody Mustang: Adding Check engine light to 86-88 cars
  • Mustang5L5
  • Nov 22, 2021
8K
Fox 5.0 Mustang Tech Dec 17, 2025
snovak
