1989 ford mustang lx hatchback 5.0 5speed 116,000miles
this car came from the factory with a 5.0 and a 5 speed, the car is silver originally white, it has 116,000 original miles, i just installed a used engine in it with 70,000 miles, i replaced all the seals and gaskets, it has new plugs, new motorsport wires, and cap and rotor. the bottom end, cam and heads are all stock.
the bad
the car needs carpet, a headliner, the front seats are leather and are cracking and have 2 tears in them, they will need to be replaced or recovered, the passenger side wheel arch has a 13"x1/2" scrape from some idiot in a parking lot that didnt bother stopping and taking care of it.
the good
new tires 275 40 17 in rear 245 45 17 in front mounted on 17" cobra r replica wheels
kyb agx adjustible shocks/struts all the way around
new trw baljoints
flaming river manual rack and pinion w/ light weight steering shaft
prothane endlinks
ford motorsport lowering springs
griggs caster camber kit
bbk cold air intake
c&l mass air w/24lbs sample tube
70mm bbk throttle body w/ 70mm egr spacer
edelbrock performer rpm aluminum intake
24 lbs ford motorsport injectors
aeromotive adjustible fuel regulator
march underdrive pulleys
king cobra clutch
ford motorsport adjustible clutch cable w/ steel quadrant
hurst shifter
ford motorsport aluminum driveshaft
msd 6 al ignitioon
msd master blaster coil
mac shorty headers
bbk off road x pipe
2.5" flowmaster exhaustj
4 core be cool aluminum radiator
proform electric fan
call me at 540 657 8056 or email me at [email protected]
car is located in stafford va 22406
