1991 LX 5.0 5-speed hatch in WA - $4000
southsounder
1991 Ford Mustang LX 5.0L hatchback 5-speed located in Olympia, Washington.
Complete undercarriage rebuild in the summer of 2006 by Brad's Custom Auto in Seattle. Basically everything mechanical but the engine and transmission was replaced or rebuilt. The suspension was set up for handling, not drag racing.
The engine and transmission are completely stock and original, my plan was to replace them as needed but so far they're both going strong. I'm the third adult owner. The car has been well maintained mechanically and has a clean title.
Many more pics available. The price is $4000 firm.
156k miles
maintenance records since new
receipts for all recent work
white w/grey interior
power windows
power door locks
GT hatch & spoiler
recent alternator
recent rack & pinion
recent EGR valve
FMS high volume water pump
A/C delete
FMS coated headers
Flowtech off-road X-pipe
Dynomax mufflers
2.5" exhaust
Hurst shifter
FMS Cobra traction-lok diff
FMS 3.55 ring & pinion set
FMS 31 spline axle shafts
Trick Flow diff cover
MM full length subframe connectors
Kenny Brown Extreme Matrix system
MM K-member brace, 4 point
MM steering shaft
MM aluminum steering rack bushings
MM sway bar end links
MM caster/camber plates
MM adjustable tie-rod ends
MM front control arms
MM front coil-over kit w/Bilsteins
Hypercoil 325lb front springs
MM rear lower control arms
MM rear coil-over kit w/Bilsteins
Hypercoil 250lb rear springs
MM standard torque-arm
MM panhard bar
Baer front track brake kit (13" rotors)
Baer rear sport brake kit (12" rotors)
BFG G-Force T/A KDWS 255/45ZR-17
FMS 17x8 Mustang GT wheels
full size matching spare
