1993 LX 5.0 dies after ignition parts replacement
  • Thread starter Thread starter Warhorse85
  • Start date Start date Aug 16, 2025
  • 3
  • 4
  • 5
  • 6
  • 7
First Prev 5 of 7 Next Last
Mindseye007
10 years still blowing strong
5 Year Member
Oct 21, 2020
586
137
63
ontario
Aug 26, 2025
#81
  • Aug 26, 2025
  • #81
Warhorse85 said:
So I circled the capacitors. The one circled in red has 37k ohms of resistance. The one circled in blue has 622 ohms of resistance. The one circled in yellow has 5.6k ohms of resistance. Now in the close up photo of the backside of the ECM, the object I have circled in red has 3.5k ohms of resistance
I think you should have the A9P ECU because your car is automatic...might solve your issue.
W
Warhorse85
66
18
18
Aug 26, 2025
#82
  • Aug 26, 2025
  • #82
So that ECU is actually a reman one. The factory tag was covered up with a solid white sticker to hide it and the was a sticker that was added that had a barcode, part number and said reman on it. I have a feeling that at one point it was for a manual trans car but was reprogrammed or they used the case from one car and the guts from another car. The car has been running fine unit a month and a half ago and I've had the car for 3 years
W
Warhorse85
66
18
18
Aug 27, 2025
#83
  • Aug 27, 2025
  • #83
So I contacted my local Ford dealer and gave them the VIN and they told me there is no difference between the A9L and A9P because the transmission is controlled by vacuum
Mindseye007
5 Year Member
Oct 21, 2020
586
137
63
ontario
Aug 27, 2025
#84
  • Aug 27, 2025
  • #84
The A9P This is a common ECU for 5.0L mass air automatic transmission models.
AOD Transmission: Models with the AOD transmission, such as the automatic 5.0L Foxbody, commonly use an A9P ECU.
Admin Dude
Jan 4, 1985
43,353
21,555
234
Box behind Walmart
Aug 27, 2025
#85
  • Aug 27, 2025
  • #85
Mindseye007 said:
Then why do all foxbody automatics come with a A9P ECU?
I vaguely recall that there were some differences in the strategy between the Auto and the Manual.
Either ECU will run either trans setup — people swap them all the time.
If you run an A9P in a stick car, it’ll work fine, just a touch smoother.
If you run an A9L in an AOD car, it’ll work but shifts can feel harsher because the ECU isn’t pulling timing where the A9P normally would.
Reactions: Mindseye007
W
Warhorse85
66
18
18
Aug 27, 2025
#86
  • Aug 27, 2025
  • #86
The reman A9L is much cheaper than the A9P too
AeroCoupe
6,122
4,214
183
Claremore, OK
Aug 27, 2025
#87
  • Aug 27, 2025
  • #87
I know that you have to repin the O2 harness if you put an A9L into an original automatic car. I would inspect the O2 harness and make sure it is correctly pinned for your application.
Post in thread 'Help Reading CEL Light'
Jun 8, 2025
Not having it pinned correctly fries ECUs. You can’t stick a 5-spd ECU into an original AOD car without repinning it first.
Needs to match the below diagram based on year and ECU.
More info here
  • Mustang5L5
Reactions: DadLife0724 and Mindseye007
General karthief
Mod Dude
Aug 25, 2016
28,041
10,660
213
polk county florida
Aug 28, 2025
#88
  • Aug 28, 2025
  • #88
Pretty common answer for a tech that has no idea unless a scanner is involved.
Reactions: DadLife0724, 5.0specialist, Mindseye007 and 1 other person
Trogdor
5 Year Member
Aug 30, 2018
195
119
53
Anna, TX
Sep 10, 2025
#89
  • Sep 10, 2025
  • #89
I thought the transmission was controlled by a TV cable.
R
rwordenjr
Advanced Member
Nov 4, 2023
260
363
73
CA
Sep 12, 2025
#90
  • Sep 12, 2025
  • #90
No update?
P
Praetorious
102
55
38
living room.
Sep 13, 2025
#91
  • Sep 13, 2025
  • #91
It is, that guy at the dealership is confused,hes thinking of transmissions before the AOD like a C4 and C6,i quit calling Ford about things with my Mustangs along time ago being that they are 30 plus years old, its like calling Boeing and asking question about the Wright flyer,after reading this whole thread it does sound like the computer has or is going south,i think the poor car had a rough life before its current owner and its starting to show it and act up, mismatched parts and awful things like that.
Reactions: General karthief
W
Warhorse85
66
18
18
Oct 25, 2025
#92
  • Oct 25, 2025
  • #92
Ok everyone, I sent the computer out for a rebuild and they were able to repair it. I sent it to fox mustang restoration and they told the there were many issues with the computer that are now fixed. Just got it back into the car and still cranks but no start. Has fuel but has no spark.
R
rwordenjr
Advanced Member
Nov 4, 2023
260
363
73
CA
Oct 25, 2025
#93
  • Oct 25, 2025
  • #93
Will die on the tfi/pip hill.
Mindseye007
5 Year Member
Oct 21, 2020
586
137
63
ontario
Oct 25, 2025
#94
  • Oct 25, 2025
  • #94
Did you check the tfi? That's what happened to me got the ecu back and my car would still crank and not start. Bought the Motorcraft TFI plugged it in and my car fired right up...ran beautifully.
R
rwordenjr
Advanced Member
Nov 4, 2023
260
363
73
CA
Oct 25, 2025
#95
  • Oct 25, 2025
  • #95
Mindseye007 said:
Did you check the tfi? That's what happened to me got the ecu back and my car would still crank and not start. Bought the Motorcraft tfi, plugged it in and my car fired right up...ran beautifully.
He did but people don’t seem to get just how bad the reliability is on brand new tfi/ pip parts. I have gotten numerous bunk brand new tfi’s out of the box from multiple manufacturers. By the way, you can actually test your tfi with a multimeter.
W
Warhorse85
66
18
18
Oct 25, 2025
#96
  • Oct 25, 2025
  • #96
It has a new tfi in it but I was thinking of putting the factory on back in it and see what happens
gkomo
now i can hopefully expect to receive the shaft
Aug 2, 2024
2,268
1,495
133
San Diego, CA
Oct 25, 2025
#97
  • Oct 25, 2025
  • #97
I haven’t swapped my TFI yet but I can attest to them not working out of the box. I bought a Motorcraft one as a backup and a TFI tester. First one couldn’t get the tester light to illuminate, exchanged it for another and it did get the test light to light up. I also tested the second one with a DVM… should have tested the first one but I didn’t know you could do it at the time.
W
Warhorse85
66
18
18
Oct 25, 2025
#98
  • Oct 25, 2025
  • #98
When I was reconnecting the battery, the wrench slipped and touched both terminals briefly and sparked. Could I have popped an ignition fuse? If so where is that located so I can check it
W
Warhorse85
66
18
18
Oct 25, 2025
#99
  • Oct 25, 2025
  • #99
Reinstalled the factory TFI module, still no spark. If I unplug the SPOUT connector, I get spark but still won't start
R
rwordenjr
Advanced Member
Nov 4, 2023
260
363
73
CA
Oct 25, 2025
#100
  • Oct 25, 2025
  • #100
Tfi is not involved if the spout is disconnected
  • 3
  • 4
  • 5
  • 6
  • 7
W
  • Locked
Fox Wifes 1993 LX 5.0 dies after replacing ignition parts
  • Warhorse85
  • Aug 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2025
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
