- Oct 21, 2006
- 515
- 43
- 49
I have a FRPP adjustable clutch cable.
To adjust , I know you're suppose to let out the cable untill there is some slack , and then tighten up on it untill there is zero lash, or no slack.
My clutch catches pretty close to the floor.
How much more can you tighten up on the cable to make the clutch engagement and disengagement a little higher?
Clutch is about 2-3 years old. The car is used about 2000 to3000 miles a year . And drag raced. I'm going by the instructions in this link.
Clutch Cable Adjustment
Thanks
1993 GT Mustang / Ford Racing GT-40 Crate Motor B-303 Cam / 24 lb. Injectors / Stock Ignition / MSD EFI Blaster Coil / Edelbrock 5.0 Upper and Lower Intake with BBK Phelonic Spacer / Professional Products 70mm Throttle Body / C&L C.A.I. w/76mm MAF / Stock Air Box w/K&N Panel Filter / Holley Adjustable Fuel Pressure Regulator / Electric Fan / BBK Underdrive Pulley's / A.C. Removed / BBK Short Headers / Flowmaster Exhaust / Tremec T-5Z / B&M Short Throw Shifter / Alum. Driveshaft / 4.30 Gears / Detroit Locker / Moser 31 Spline Axles/ Subframe Connectors / Line Lock / Driveshaft Loop / BMR Upper and Lower Control Arms / Lakewood Adjustable Drag Shocks/ Holley 190 lph Fuel Pump /
Thanks
