1993 Mustang Project 4cyl To V8 Swap
  • Thread starter Thread starter Project 1993 fox mustang
  • Start date Start date Nov 12, 2015
First Prev 2 of 2
L
Lscam580
119
18
28
Grand Rapids Mi
Nov 13, 2015
#21
  • Nov 13, 2015
  • #21
I do have an extremely lot of extra parts that I'd be willing to donate
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 13, 2015
#22
  • Nov 13, 2015
  • #22
The whole 2.3 to 5.0 conversion was been well covered and documented in What exactly do I need to convert mine to 5.0 | Mustang Forums at StangNet
Your best bet is to buy an 87-93 5.0 roller chassis to rob parts from. Beat up or wrecked, as long as the drivetrain is in tact, you'll have the parts you need without going broke or crazy trying to find them.
P
Active User
Nov 12, 2015
Indiana
Nov 14, 2015
#23
  • Nov 14, 2015
  • #23
stykthyn said:
Sure, I mean it's not like these are collectors items. If you want to spend your time and money sourcing the needed swap parts that are already on av8 car jump on it. The op said on a budget. Nothing about a swap without already owning all of those parts in the dorm of a donor car is budgetary.
But let's make that list he needs and dollar signs subjective depending on quality and condition
Motor and trans trans
Driveshaft
Carb and intake
Carb friendly distributor
Fuel pump
Carb Friendly Fuel Tank
Exhaust
Starter
Motor mounts
Rear end since that 7.5 will explode and has an open diff to boot
Ignition box
Probably a good idea to replace that worn suspension including springs, struts, and control arm bushings.
Trans mount
New radiator
Tranny cooler
Depending on his engine choice he may need a whole new accessory set up
Throttle cable
Kick down cable
Are we leaving stock 4cyl brakes?
Stock k member will work but the v8 unit is wider allowing more room for brakes and tires.
5 lug swap?
I am leaving the breaks and k member for now but what motor mounts do I need ?
L
Lscam580
119
18
28
Grand Rapids Mi
Nov 14, 2015
#24
  • Nov 14, 2015
  • #24
Throw the 2.3 mounts away, need to buy 5.0 mounts. If you go with with convertible mounts,the motor sits lower in the car not hitting the k member but low center gravity.
L
Lscam580
119
18
28
Grand Rapids Mi
Nov 14, 2015
#25
  • Nov 14, 2015
  • #25
The 5.0 mount stud will bolt in the upside down teardrop hole
P
Active User
Nov 12, 2015
Indiana
Nov 14, 2015
#26
  • Nov 14, 2015
  • #26
Where u located ?
P
Active User
Nov 12, 2015
Indiana
Nov 14, 2015
#27
  • Nov 14, 2015
  • #27
What auto tranny should I go with ?
P
Active User
Nov 12, 2015
Indiana
Nov 14, 2015
#28
  • Nov 14, 2015
  • #28
That would be so awesome
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,946
5,818
213
Nov 14, 2015
#29
  • Nov 14, 2015
  • #29
The ford c4.... AOD transmission are OK for mild builds but are slush boxes. They both have pretty good aftermarket support. I haven't run automatics in any of my mustangs. Guess the deciding factor is if you want overdrive or not. I don't think a c4 ever came with overdrive...the AOD is overdrive but can only handle so much power. Then again I don't know squat about autos... Lol
L
Lscam580
119
18
28
Grand Rapids Mi
Nov 14, 2015
#30
  • Nov 14, 2015
  • #30
Yeah I live in Michigan, it's about 2.5 hrs to Indiana and depending on where you live is the hourly factor. No bigge when I drive a vw Passat tdi getting 63 mpg on open highway.
But mustangs mustangs ah yes. C4 is good for upgrading the valve body's and I never liked an aod for mustangs. They never lived up to the abuse my foot would give to it. But true a t5 is better. I have killed a few c6's. Memory recalls about 6 miles on a fully built c6 trans and 27 lbs of boost I hit trans button at 4K and herd a pop in trans and about 6 miles later it was toast when I flat footed the car making full boost and I walked back to pick up chunks from the middle of the road.
P
Active User
Nov 12, 2015
Indiana
Nov 14, 2015
#31
  • Nov 14, 2015
  • #31
Right on man well what all do you have ? I could make that trip easy
P
Active User
Nov 12, 2015
Indiana
Nov 15, 2015
#32
  • Nov 15, 2015
  • #32
I am just at a stand still until I get some money together for a bunch of parts but I plan on having everything together here in a month or less
First Prev 2 of 2
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
For Sale 1993 Mustang SVT Cobra - Black - 5 Speed - 88k Miles - Single Owner
  • Buddy Jake
  • Jun 16, 2026
Fox Body Mustangs For Sale (1979-93) Jun 20, 2026
Habu135
P
market for 2.3L? i wanna sell
  • Patk
  • Dec 6, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Dec 7, 2025
rednotch
