Electrical 1995 Cobra Ignition Switch Power Issues
DualXhst289
25
To put it simply, the power supply line going into my ignition switch is going cold when putting the switch in the "start" position. The only way i can get it the engine to crank is to putt the switch into the "run" position and jump the yellow power supply line to the white/ pink line, on the back side of the connector, that leads to the starting system. The switch is currently hanging from the dash because i doubt have the ignition key and in removing the old key cylinder, the ignition tamper sensor was destroyed.
The anti theft is bypassed and i have not replaced the key cylinder yet because i have been unable to find a replacement tamper sensor.
Ignition switch is new and passed continuity test.
What i am currently trying to diagnose is why that power wire is losing power when the ignition switch is put into the start position. Ideas?
I just recently got this car from auction. It has no mods of any kind.
