1997 V6 stang water in floor pans
camgrind
Wardensville wv
I fixed one problem, water on drivers side it was the hood release cable grommet. Still have water coming in on passenger side around the a/c vent tube on the inside! I need help ! How do I fix this? It would be greatly appreciated!!
Has this car been in an accident? Double check for "creased" metal in the firewall where the AC drain line goes through the firewall. If seen likely the crease has cracked the bottom of the AC drain unit such that it's leaking inside the passenger compartment instead of draining outside.
I'm not sure if it's been in a wreck. I have had a air line in the drain an ran something in the drain also. thinking it was clogged. So I'll check the firewall. Thank you ! I'm also getting water in my trunk an it's soaking my rear seat. I'm ready to trash it! Thank you !
