1998 Explorer engine into 88 fox???
  • Thread starter Thread starter johnf440
  • Start date Start date Aug 21, 2004
First Prev 2 of 2
J
johnf440
28
#21
  • Aug 22, 2004
  • #21
Tom, also, I almost forgot. I am probably in the neighborhood of 30-40 minutes from where you live. If you decide to do the oil pump, let me know. I am a pretty good supervisor.. later
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 22, 2004
#22
  • Aug 22, 2004
  • #22
johnf - HP peak at 4900; torque peak at 3800. I told Buddy (custom cam Rawls) that I didn't want it to peak over 5000 rpm (hp) cause I wanted the lower torque curve to be big, fat and flat. Don't get me wrong, it revs easily to 5500 especially in 1st and 2nd. But in 3rd and 4th, there's just no need going up there as I'd make more progress shifting, and letting it drop back to the fat part of the torque curve. As you're checking around, be sure to ask about the heads and intake being used - we (you and me) have about the least flowing of the aftermarket heads available and the cam will of course behave differently with different heads/intake. Nice job on the oil pump tips!
Tom - if you don't drop the tranny, be sure the drive shaft ujoints are oriented in a way that the engine can be pivoted up without putting the joint in a bind.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Aug 22, 2004
#23
  • Aug 22, 2004
  • #23
johnf440 - My car carries power through 5,400 rpm and torque is really fat through the whole curve - 284ft-lb average from 2,000-5,600 rpm. My cam valve events are very close to the 15510 Crower and fairly close to yours, but I don't have their lift. I am posting a copy of my dyno for you to see. Your cam has 4* advance ground in, so I ran your events and yours will be pretty close to mine.
Here our valve events and yours @ .050" lift:
mine: IVO=.5*, IVC=42.5*, EVO=43.5*, EVC=-7* with -9* overlap
yours: IVO=-4*, IVC=36*, EVO=47*, EVC=-9* with -13* overlap
Power band may be very similar too.
J
johnf440
28
#24
  • Aug 23, 2004
  • #24
I would love to have that obscenely flat torque curve. Are you still SD? I am considering whether I need to go Mass Air with the engine change and have read much on 50tech.com that says I may not "need" to but I might want to. Oh well. I need to get that engine in my garage and get to work. Thanks guys.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Aug 23, 2004
#25
  • Aug 23, 2004
  • #25
Yes, I'm still SD. My combination was built to make torque first - I really was not too worried about peak HP, although I knew about where the number should be. I may have 10-20HP left in the tune. This car is such a joy to drive, I can let the clutch out with minimal to no throttle input and just pull away on reasonable inclines. I taught my daughters to drive a performance car with my original set up, and now my oldest is rabid over driving the car now.
First Prev 2 of 2
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
