Aftermarket superchargers owners read this!!
Anyone running the stock 19lb injectors with a supercharger without any drivability problems?
I'm running a Procharger w/ 9psi boost, 3 core intercooler and the stock injectors. Problem, high speed flat spot at 4000 rpm's under 3/4 throttle. I can drive thru this problem under full throttle. Anyone been thru this before. Otherwise the car runs fine.
Thanks.
Anyone running the stock 19lb injectors with a supercharger without any drivability problems?I'm running a Procharger w/ 9psi boost, 3 core intercooler and the stock injectors. Problem, high speed flat spot at 4000 rpm's under 3/4 throttle. I can drive thru this problem under full throttle. Anyone been thru this before. Otherwise the car runs fine.
Thanks.
