- Oct 21, 2006
- 322
- 4
- 18
I'm going to build an 89 (I think) 2.3 for the local autocross track, I know that is an odd setup, but there are some Miatas that I need to get even with.
It has to be "stock", let me explain that one.
"Stock" in this case, means the parts have to be stock, the car can be stripped (including the addition of lexan for glass) but the suspension and engine have to be close to factory stuff.
It'a 2.3 so it has the 4 lug wheels/brakes/7.5 diff, etc.
Here's the plan:
I think the 4 lug GTs had bigger brakes, which parts will I need to swap over to make that work? (from ? year)
Will the vert front unibody brace and subframe connectors fit the 4 banger chassis? (from ? year)
Besides pulleys, and a cam timing adjuster, what cam could I use, and how far can you cut the head to raise compression?
Headers? (source)
What aluminum flywheel and clutch will fit (source)
I'm planning to use GT sway bars and springs (cut) with Tokico shocks, (I think the biggest rear bar came out of an Fairmont Wagon, will this fit?)
Where can I find some (at least) 9 inch wide, 4 lug wheels with the proper offset? (I don't mind massaging the fenders a little).
Anything else you can think of would be appreciated, those little turdhopper Miatas are very tough to beat on the short courses that we have to run on. HP to weight will be my biggest issue.
Thanks for your time.
Here's the plan:
Headers? (source)
