2 HUGE Problems...HELP-HELP-HELP!!!!!!!!
302efi
273
Sunny Florida
I'm doing the 4 cyl to carbed 5.0 swap.The 4 cyl car is automatic and I swaping in a 5 speed. The problem is my 4 cyl car does not have clutch pedal saftey switch. It doesnt even have the harness for it...WTF do I do ? Is there someway to bypass it ?
the second is also relating to this. Since the 4 cyl car ia automatic, what do I do about the starter saftey switch on that ? I just left it unpluged, Will that cause problems starting the car ?
I need help fast, It has to running by Friday!!!
The switch should be there, it should just be jumpered with a plug. It's up along the sidewall. If the jumper is on there then it is bypassed so you could go ahead and start it without it plugged into the clutch pedal assembly, just make sure it's outta gear if you dont have the clutch pushed in...
You could and if you do just jumper it also
