1- subframe connectors on a convertible? ive looked at subframe connectors and i havent seen anything about not fitting a convertible. while i was under my vert i dont see how they will fit. all the chassis bracing covers over where the subframes would weld in or bolt in. or is the chassis bracing enough.
2- do someone make a removable 4pt roll bar and still be track legal? ive seen some cages with door braces that has a pin and the bar swings out for easy access. just curious to know if there is a setup where the plates would be welded to the chassis and roll bar would just slip on with a slide in pin. i dont see how a setup like that would be any good as far as rigidity and saftey, but i could be wrong. just curious for convertible owners that dont want to look at a roll bar with the top down.
chime in......................
