Black Sun 5.0 Founding Member Mar 23, 2002 1,337 0 36 L.I., N.Y. Aug 17, 2005 #1 Aug 17, 2005 #1 What's the deal with this? I just put a smog pump in last summer, now the 'new' one is going out too. Anyone see this before?
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Aug 17, 2005 #2 Aug 17, 2005 #2 If it is used pumps being installed, that can be it. They dont like to not be turned (i.e. if someone 'belts' around the pump for a long time, the pump might not like being spun again). Good luck.
I iwashmycar 20+ Year Stangneter Apr 7, 2004 1,236 1 39 Columbus, Ohio Aug 17, 2005 #3 Aug 17, 2005 #3 if you dont have a stock H-pipe that may cause it to burn out i think
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Aug 17, 2005 #4 Aug 17, 2005 #4 iwashmycar said: if you dont have a stock H-pipe that may cause it to burn out i think Click to expand... I think you are thinking of the check valve in the line from the pump. It keeps backfires from making it back to the pump (which can damage the pump). The pump does not really care what it pumps to, otherwise.
