Guys my GT is spark knocking really bad when Im in 5th gear or any gear when there is a medium load on the engine for example like 4th gear at 35mph it spark knocks or when I add more than a 1/4 of the throttle when its in 5th gear.
I put the car back to stock on the SCT Tuner except I went through the tuner and did the strategy tune , the only thing I changed was that I kept the rear end axle ratio at 3.73 because of the gears. I even put the stock intake back on the car and its still doing it.
What are my options right now? I was told that I should get some throttle body cleaner to clean the throttle body and the MAF. Is the MAF the wire mesh thing that goes in between the intake filter and sensor? Also should I get some seafoam or get octane booster and add it to the gas tank? Right now I have a full tank of 87 octane fuel in the car.
It wont spark knock when I drive the car normally, it only does it when the cars engine is under a load in 3rd of 4th gear and i have the pedal 3/4 of the way or at wot starting out at around 2000-2500rpms or when I add 1/4 of the throttle in 5th gear at 1500rpms it spark knocks bad.
Also I might add that the car has Bosch Platinum spark plugs in it and they have about 30,000-32,000 miles on them.
Thanks for the help guys I really appreciate it, I just want to drive my Mustang without fear of destroying my motor.
