- Nov 13, 2016
- 194
- 56
- 48
Hello, I have an 03 Mach 1 and I’ve just recently started having an issue with the headlight switch. When it first started I noticed the gauge cluster lights weren’t on as well as the fog lamps, but everything else worked headlights taillights etc.. then two nights ago I noticed the taillights had quit. So yesterday I went to buy a new headlight switch as I noticed I could put it in just the right spot and get it to work everything. So when I got the switch out the connector seemed burned some so I was sure it needed replaced too. So I bought the connector today and installed both and still nothing. So I checked fuses and the park lamp fuse in the under hood fuse box was blown. So I thought sweet the short that burnt the connector blew that fuse so I replaced it and everything seemed to work after that. I tested it a few times and it all seemed good... right up until I had to turn my lights on when it started raining this afternoon. That’s when I noticed the gauge lights weren’t on after a few minutes. And I then thought I might have smelled something, but that could just be me being paranoid. I pulled the bezel out and took the switch back loose and nothing seemed burnt or out of place in there but the fuse blew again. I did notice even with the fuse blown I could put the headlight switch in just the right spot to get it to work the gauge lights at least, so I’m real confused on what to do next.... Please Help
