I recently had installed 275/40/17 MT Drag Radials and 245/45/17 Fronts.
They are a smaller diameter tire, and now the wheel gap is truck like.
First issue was with the diablosport; It has no ability to input tire height/diameter as stated in the instruction manual. I've adjusted the speedometer using modify tune/axle ratio/tire revs per mile. Thank god for the online calculators.
I'm getting some conflicting information from my local shops regarding how to lose the gap. Steeda.ca is telling me anything other than 1inch drop will change pinion angles and such and will hurt the car's drag strip aspirations.
Other shops are telling me 1.75 front and 1.5 rear drop is doable.
Do I need camber plates?
What's a reasonable height to drop to get rid of gap?
I went from a stock 27.18in tall tire to a 25.66in tall tire on all 4 corners.
Suggestions?
Thanks in advance!
Suggestions?
Thanks in advance!
