2005 V6 - 2 Or 4 Wheel Alignment And Which Moog Tie Rod Ends W Or W/o Zerk Fittings?
bighank
Maryland
Have bad OEM outer tie rod ends. Considering replacing them with Moog TREs.
Which ones? With zerk fittings (ES80805) at about $35 each or without zerk fittings (ES80804) at about $49 each? Both have lifetime guarantees.
Will need an alignment. Since it is a RWD car does it need only a 2 wheel alignment?
If not how do you align the rear wheels?
Changed outer and inner tie rods - alignment next
After removing outer tie rod found inner tie rod very loose. Removed and replaced both on both sides.
Will align next. Seems like you have to pay for a 4 wheel alignment whether you need it or no
