2006 Mustang Cobra "discountpartcenter"
05Stangster
113
Austin, Texas
2006 Mustang Cobra - thought this was fun to read and a real black beauty!!!!!!!!!!!!! :spot:
465HP, 6-speed manual running in the low 12's with a trap speed of 120mph! You choose the rear suspension set up, either IRS or Solid Rear Axle with the IRS apparently pulling over 1.0g in the corners. 5.4 Supercharged, 3 valve heads (with HUGE valves), forged internals similar to the 4.6 (Crank, rods, etc), modestly rated (under rated actually) ~465 HP/495 lb ft Torque, using a twin screw S/C similar to that on the Ford GT but pullied differently, hence the lower HP.
Attached the link b/c I wasn't sure the jpeg attached to the post.
http://www.discountpartcenter.com/photos/01-24-05-01-2006-Mustang-Cobra.jpg
that chop has been around more than a $2 hooker in Tijuana. Not real. Look at the side exhaust. That's not even possible (well it is, but the amount of work it would take to do it, no aftermarket company would do). Plus, if you look around, you'll see that's the same background and everything as Ford's promotional pictures for the Mustang. They just changed the color. In fact, here's the exact picture
attachment.php
