Expired 2007 Mustang Gt Supercharged Mammoth, 63983 Miles, 3-4k Mile Motor
Chad W.
Myrtle Beach, SC
Selling my 2007 Torch Red Mustang GT. I'm pretty tore up that I have to let my baby go but I am in the early stages of opening another business and need some extra capital to launch it.
Anyhow onto the details..
I'm located in Myrtle Beach, SC - home to Mustang Week. Car has 63983 miles on it, with between 3-4k miles on the rebuilt Fastlane Motorsports block.
Asking $35,500. NOW $25,500
678 RWHP @ 22.75psi on 93 octane & meth!
696 RWHP @ 22.75psi on c16
More images here
View: http://imgur.com/a/x3NQi
and here
View: http://imgur.com/a/fM3EP
Dyno Run @ Fastlane Motorsports 2013
All mechanical work and tuning done by Fastlane Motorsports in Benson NC.
Autobody work, Paint and Airbrushing done by MPT Autobody in Murrells Inlet, SC.
Engine
Custom Fastlane Motorsports Long Block
Custom Cams
Diamond 4.6 3v -6cc 3.572" Bore Piston Set
Eagle H-Beam Rods
8 Bolt Steel Cobra Crank
Melling Billet Oil Pump
Canton Oil Pan
Canton Windage Tray
Stage III Port & Polish heads
ARP Head Studs
80LB Fuel Injectors
Fluidyne High Performance Radiator
Kenne Bell Mammoth 2.8L Supercharger
8 Rib Belt Upgrade
Snow Performance Stage II Methanol System
Fore Innovations Fuel System w/ 2x 405LPH pumps
Drivetrain
Tremac Magnum XL T56 6 speed
McLeod RST Twin Disc Clutch
McLeod 8-Bolt Steel Flywheel
1PC driveshaft
Steeda 1 Piece Driveshaft Loop
Moser 31 Spline 8.8" Axle
Eaton Detroit True Trac
3.73 Gears
Welded Axle Tubes
Exhaust
Kooks 1-3/4" x 3" Stainless Steel Long Tube Headers w/ Jet Hot Super 2200 Extreme Coating (Black)
Kooks 3" x 2.5" Stainless Steel O/R X-Pipe
Flowmaster Outlaw Axleback
Suspension
Maximum Motorsports Caster Camber Plates
Tokico D-Spec Shocks & Struts
Steeda Ultra Lite Lowering Springs
Steeda Street Adj 3-Link Control Arm
Steeda Billet Lower Trailing Arms
Steeda Rear Sway Bar w/ End Links
Steeda Adj Front Sway Bar
Steeda Adj Panhard Bar w/ heavy duty brace
BMR K-Member
BMR Subframe Connectors
Brakes
Brembo 14" upgrade
GT500 Brembo cross-drilled & slotted rotors
Wheels & Rubber
Front Wheels: Race Star Drag Star 15x10
Front Tires: M&H Racemaster 185/55R17 radial skinny
Rear Wheels: Race Star Drag Star 17x4.5
Rear Tires: 325/50/R15 Drag Radials
Interior
MMR Rear Seat Delete
Custom 8pt Fastlane Motorsports Roll Cage using 1-5/8" .083 Chrome Moly Tubing w/ Swing out door bars
Corbeau LG1 Seats
Corbeau 5pt harness
Speed of Sound Concept 1 center dash pod w/ Boost, Wideband A/F, Electric Fuel Pressure gauges
Raptor Shift Light
Momo USA Race Wheel
Pioneer AVH-4100NEX Head Unit
Exterior
Cervini's 4" Cowl Hood
GT500 Rear Spoiler
Agent47 Retro Race Mirrors
SHR Flush Mount Quarter Window Louvers
Roush 9 Bar Black Billet Grille upper & lower
Smoked tail lights, 3rd brake light, bumper lenses
More images here
and here
I'm sure I missed a few things, so if you have any questions please let me know.
Thanks,
Chad
