2009 Gt500 Rear End Housing Installation
Dec 25, 2007
62
Does anyone have or know where to find all the torque specs for installing a complete new housing into a 2009 GT500? I am talking about the torque specs for upper/lower control arms bolts, sway bar bolts, panhard bolts, shock bolts, etc...
Thanks!
Hey Max:
Upper control arm-to-frame, interior:129 ft. lbs
Upper control arm-to-frame, exterior:85 ft. lbs
Upper control arm-to-axle:129 ft. lbs
Lower control arm-to-chassis:129 ft. lb.s
Lower control arm-to-axle: 129 ft. lbs
Sway bar link-to-chassis bolts 85 ft. lbs
Sway bar bracket nuts 52 ft. lbs
Panhard rod, all: 129 ft.lbs
Shock-to-chassis: 30ft.lbs
Shock-to-axle: 85 ft. lbs
According to Haynes. Good luck.
Reactions: racerraj
