210 freakin degrees!!
CManT1914
3,172
Killeen, Texas
Since I installed my autometer temp. gauge, I've found that I generally run around 210 throughout the day (early in the morning around 195). That seems really hot, and probably explains why my car hates bumped timing. I have a 180* t-stat in, is there anything else I can do (relatively cheap) to make my car run cooler?
WhiteDevil
2,717
San Diego
No your low speed fan does not come on until 210 degrees so thats why it gets that hot. I was shocked that mine did too even with a fluidyne and 180 stat. When i got my tweecer i put my fans to come on at 185 and my car never goes above that.
HISSIN50
33
129
low and high speed fan switches might help, Chris. Now you know why i love gauges so much (you knew that from the posts on the fox side). :)
I too have been hitting 210 - the Griffin alum radiator was ordered today!
Good luck bud. :nice:
RIO5.0
6,892
N.H.
Don't worry about it...Its the norm for these cars...I did my gage and freaked at first when I hit 200...The more I ran it, the more I noticed it ran fine all the time like that...I run a stock 192 stat and radiator too...I run 14 degs with never a hint of detonation...
I may see mine go to 208 at a light idling...It run's the balls all day long like that...They like the heat I guess :D
Sometimes I turn on the fan at a light and it kicks it down 10 deg's in minutes...Then shut it off when moving again....
Mine pretty much runs a tad under 200 all the time...It doesn't even phase me anymore....
CManT1914
3,172
Killeen, Texas
Ok, thanks for the info guys. It really puts my mind at ease. I read that post (in the 94/95 FAQ section) about the manual fan switch, but despite my high school electrician's course, I can't read a wiring schematic for the life of me. Does anybody have a simple dumb-it-down how-to for me to run a manual switch? I would like to do that this weekend maybe. Thanks again guys!
Chris
HISSIN50
33
129
for a low speed switch: grab a switch from the parts store. find a 12 volt Key-on hot feed (like how you did your gauges; when the key is on, the wire has 12 volts. When the car is off, the wire is dead.). I mounted a switch panel in the ashtray so i used the harness for the vert top. on the 'accessory' terminal of the switch, attach a wire to run to pin 14. now you have a low speed fan switch. (You can also put a grounded wire on the ground terminal of the switch if the switch illuminates).
For high speed: find a real clean ground near your switch's location. run that to the 'power' terminal of a second switch. from the accessory terminal on the switch, run a wire to pin 17 on the CCRM. you can use LED's etc (Shane has a diagram for that), but you dont have to.
Post or PM if that was hard to follow (articulate, I am not!).
good luck bud!
WhiteDevil
2,717
San Diego
Yeah wireing that is cool and all but iwould jsut leave it, Its not hurting the car and all. I am really glad i never messed with the wireing now beccause now i can set it to come on whenever i want with the tweecer. Or any tuner for that matter.
HISSIN50
33
129
This is all very true (and boy would i love to do that too - as you might have gathered from long posts with Grady and you (to a lesser extent). :) ).
But there is nothing permanent done to the wiring, and the switch(es) is/are a good idea, IMHO. Don't get me wrong, a TwEECer would be SWEET, but for the meantime........ :)
CManT1914
3,172
Killeen, Texas
good luck bud!
So I'll need two switches. Low speed switch is as follows:
Power terminal: ignition-hot lead
Accessory terminal: Pin 14
Ground terminal: ground wire (I like the light-up switches :D )
The high-speed switch is as follows:
Power terminal: ground wire
Accessory terminal: Pin 17
Ground terminal: ignition-hot lead?
What is the CCRM? Is that the wiring harness for the fan? Thanks JT
EDIT: CCRM = Constant Control Relay Module, that's the thing the connector plugs into right?
