24lb Injectors, Waste of Gas?
SN95Oh
91
Oklahoma
I was thinking about getting 24lb injectors, but what I was wondering with the mods I have now. Would it help or would it just be a was of gas and money.
The only mods I have are 3.55 gears, Exhaust, Trickflow Street Heat Intake, and a adjustable fuel pressure regulator.
But I plan on getting bigger throttle body, MAF, and a B303 cam.
With those mods, is it worth it?
I went with the 24's because I planned on upgrading my heads/cam down the road. Everything was fine, don't listen to anyone about pulse width junk and what not. Your computer will compensate on normal driving, and put it on a wideband too see if you're running too rich at WOT, if so you can turn your fuel pressure down to 36psi WITHOUT effecting the spray pattern.
