24lb Mass Air Meter Questions......any Junkyard Swaps?
  • Thread starter Thread starter BKM48198
  • Start date Start date Dec 26, 2014
  • 3
  • 4
  • 5
1 of 5 Next Last
BKM48198
377
27
49
Ypsilanti, Michigan
Dec 26, 2014
  • Dec 26, 2014
I have a 70mm Mass air meter calibrated for 19lb injectors but plan on going up to 24lb injectors, did any vehicles come stock with 24lb injectors where the mass air meter is compatible with a Fox body? I do know the 24lb injectors came on Navigators and some trucks, just not sure about the mass air meter.
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
Dec 27, 2014
  • Dec 27, 2014
93 cobra, ecu is setup for 24's though
addermk2
5 Year Member
Aug 25, 2009
308
87
49
Dec 27, 2014
  • Dec 27, 2014
There are no factory meters that can be installed that will allow you to run a larger injector that stock. period. The EEC logic has a defined curve programmed into it known as the "Mass air transfer function". This table tells the ECM what each voltage output from the MAF equates to. Factory MAF's are not "calibrated" they simply put out a signal and the ECM interprets it. This "mass air transfer function" can be changed, which allows you to run different meters (like my HPX, or an LMAF.. etc etc etc).
If you would like a good, cheap, sure fire way to run those 24# injectors, and don't want to buy an expensive aftermarket maf, PM me.
Reactions: Dogman_1969, 88mustang on a budget and Mustang5L5
BKM48198
377
27
49
Ypsilanti, Michigan
Dec 27, 2014
  • Dec 27, 2014
I didn't think there were any that would work for 24# injectors but wanted to check, I found an older Pro-Flow meter, 75mm bullet for $50, same as the Pro-M meter but Pro Flow either changed their name or was bought out, Pro-M says they do recalibrate the Pro-Flow meters if there are any problems with it. Even if I had to send it for a recal. I'd be saving 1/2 off what they sell for new. Recal is $100, new they sell for $299.
addermk2
5 Year Member
Aug 25, 2009
308
87
49
Dec 27, 2014
  • Dec 27, 2014
might want to PM me before making that purchase.
BKM48198
377
27
49
Ypsilanti, Michigan
Dec 27, 2014
  • Dec 27, 2014
I don't know how to do that on here.
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
Jan 8, 2015
  • Jan 8, 2015
I used a slot meter from an 05+ mustang on my last build, I have a qh to change the maf transfer though. Using a high flow hpx on my next build.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 8, 2015
  • Jan 8, 2015
Click on the user name of the person and when the information box with his avatar pops up, click on Start a Conversation
Reactions: BKM48198 and A5literMan
addermk2
5 Year Member
Aug 25, 2009
308
87
49
Jan 12, 2015
  • Jan 12, 2015
Im glad some brought this up. The HPX conversion is super simple. If the 05+ is a 6 wire maf plug, then using an HPX should be a drop in swap... aside from setting the transfer function. I personally use a Power Adder Solutions HPX in my car.
Reactions: f8tlfiveo
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
Jan 12, 2015
#10
  • Jan 12, 2015
  • #10
Yes it is the same plug, unfortunately I had this setup 2 vehicles ago so it is not in my current vehicle. So will have to wire the plug into this car. I think I only used 4 of 6 wires when I did the conversion. The 05 mustang sensor I had to use a 3.5" tube to get the sensor not to peg. But the hpx I think is good for the 3" tube because it is high flow. I have had all the stuff to turbo my car for about 2 years now. Just haven't had time to get it on the car. Doing a gt40, explorer intake and tfs-1 swap right now.. Maybe next winter
9
91gtfox
20
#11
  • Feb 21, 2015
  • #11
Im
BKM48198 said:
I have a 70mm Mass air meter calibrated for 19lb injectors but plan on going up to 24lb injectors, did any vehicles come stock with 24lb injectors where the mass air meter is compatible with a Fox body? I do know the 24lb injectors came on Navigators and some trucks, just not sure about the mass air meter.[/QUOT I'm runnin a 98 cobra mass air that's calibrated to my 24lb injectors on my 91 fox, works good. I was told it couldn't be done but called jegs, worse case is a rough idle as if it is cammed. But since the computer isn't actually calibrated for this it actually runs rich an that's a 80mm mass air, but until I can get a bigger one it's fine. I would recommend a cold air intake so you have more air so it want run so rich.
91gtfox
20
#12
  • Feb 21, 2015
  • #12
91gtfox said:
Im
I'm runnin 24lb injectors with a 98 cobra mass air that's calibrated for them. Was told it couldn't be done but tried it and it worked, yes you are limited to certain things you can do without a tune but these foxes aren't as sensitive as a lot think, I also have gt40 intake, 65mm tb cold air intake and egr delete.
Reactions: BKM48198
BKM48198
377
27
49
Ypsilanti, Michigan
Feb 21, 2015
#13
  • Feb 21, 2015
  • #13
I sold the 24lb meter and injectors and bought some 1.7 roller rockers and a 255lph fuel pump, now I'm looking for a higher stall torque convertor for the car.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,359
209
114
Ohio
Feb 21, 2015
#14
  • Feb 21, 2015
  • #14
The 1993 Cobra came from the factory with 24 Lb Injectors, if you use the EEC and Meter from the 93 Cobra then you can use the 24 Lb injectors without a tune or and aftermarket meters.
90lxwhite
I'm kind of a She-Man
5 Year Member
Aug 25, 2011
3,310
374
134
Between the Red and Rio
Feb 21, 2015
#15
  • Feb 21, 2015
  • #15
Yeah, what he said... In laymans terms: An oem maf will work w any injector size. The maf "calibrating" is done w the computer via tune. The advantage of aftermarket "calibrated" maf's is the larger size so more air can go through.
That being said, @BKM48198 I know you sold them but switching to 24lb injectors wouldn't/won't gain you anymore power, you might even lose a little. Therefore one couldn't justify the cost of either an aftermarket "calibrated" maf or a tune to make it work.
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Feb 21, 2015
#16
  • Feb 21, 2015
  • #16
What cylinder heads do you have?
*Edit* I just read your post on the tq converter. Since you have an explorer motor 24 lb injectors plus a tune would probably be worth it. A little on the high side I know but you'd get some bang for your buck.
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Feb 21, 2015
#17
  • Feb 21, 2015
  • #17
Reactions: addermk2
BKM48198
377
27
49
Ypsilanti, Michigan
Feb 22, 2015
#18
  • Feb 22, 2015
  • #18
90lxwhite said:
I'm going to see how it does with the 255lph fuel pump and rebuild the injectors. I had bought a75mm Pro Flow Technologies ( Pro-M) Bullet meter and 24lb blue injectors because I found a GREAT deal on Craigslist $65 for meter, injectors and rebuild kit, but sold them to get the fuel pump and 1.7 crane roller rockers. I don't plan on any power adders for the car so the 19lb parts should be enough to support the HP my engine will make.
9
91gtfox
20
#19
  • Feb 22, 2015
  • #19
I'm going e303 mines auto also
addermk2
5 Year Member
Aug 25, 2009
308
87
49
Feb 22, 2015
#20
  • Feb 22, 2015
  • #20
You can do ALOT better with your cam choice. E303 doesnt belong in a factory engine.
  • 3
  • 4
  • 5
1 of 5 Next Last
Fox Mass Air Flow 42lb injectors
  • 89wreck
  • Aug 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2025
Scrapla347
Z
Engine New head for ‘88 mass air converted foxbody
  • zahirayunus
  • Dec 13, 2024
Fox 5.0 Mustang Tech Dec 13, 2024
zahirayunus
Z
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
O
Computer swap
  • Oakman
  • Jun 22, 2024
  • The Welcome Wagon
The Welcome Wagon Jun 22, 2024
Oakman
O
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
