289 Heads
FoxGT87
5 Year Member
Aug 1, 2009
1,518
St.pete FL
i have been seeing people say that they put 289 heads on their 302 block, what does this acomplish. can i keep my top end the same with out changing anything.
out side of that is their any economical heads out there that would be a good upgrade from stock, is a GT40 head my only choice? i know that sitting on my 302 now is iron heads so im assuming they are stock.
All they do is raise compression. The early non-Thermactor 289 heads will also disable some of the smog pump system. You would be better off having the E7s worked over or buying GT40s, Roush iron heads, or shopping around for some used aluminum heads.
Unless you can find a good pair of Hi-Po 289 heads for next to nothing, I'd say don't bother. You can find good used GT40 and GT40P heads in ebay for not more than $300. If your budget can stretch to $500 or more, you might get lucky and find a pair of used aluminium heads.
