289???in a fox
  • Thread starter Thread starter ls1beater4eva
  • Start date Start date Sep 5, 2008
ls1beater4eva
334
mooresville
Sep 5, 2008
  • Sep 5, 2008
ok i have a friend who is wantingt o put this 289 in a fox and he is wanting to use his oil pan pump and pick up since its a almost brand new canton pan wil these work on this 65 289? allso he is wanting to convert it to roller and stay fuel injected will this be a problem i was thinking allmost all this stuff is inter changable but i really wasnt sure about the cam part of it or if he has to buy a small base circle cam? thanks in advance im sure sombody will have some input
Maryland Stang
1,656
30
39
Greenville, NC
Sep 5, 2008
  • Sep 5, 2008
The non Fox oil pans are front sump and Foxes require a rear sump. His oil pan will not work.
ls1beater4eva
334
mooresville
Sep 5, 2008
  • Sep 5, 2008
ok well the oil pan is offhis old 302 that come out of his fox i was asking if that will work on his 289 .
93 LX
3,081
Norwalk, CA.
Sep 5, 2008
  • Sep 5, 2008
since the 289/302 use the same block it would work, he would have to relocate the dip stick since the 5.0L has it in the side of the block not in the timing cover as the 289.
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Sep 5, 2008
  • Sep 5, 2008
why? srsly
93 LX
3,081
Norwalk, CA.
Sep 5, 2008
  • Sep 5, 2008
BK_CAULEY said:
why? srsly
Because it is a rear sump oil pan and the serpentine belt system.
Fast63
717
  • Sep 5, 2008
I think it would be stupid to put a 289 in a fox. Why doesn't he use his original 302? converting that thing to a roller is going to be expensive.
IMO there is zero advantage of a 289 over a 302.
These other guys are giving you the right responses as well.
NKau
1,346
Jefferson, WI
Sep 6, 2008
  • Sep 6, 2008
No real reason it can't be done, except converting over to a roller cam is prohibitively expensive. Unless this 289 is already built, your friend might be further ahead selling his 289 and scooping up a roller motor to start with.
Beasty306GT
671
Oxford,Mass
Sep 6, 2008
  • Sep 6, 2008
honestly hes wasting his time and money tell him to put a 302 in it
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
F
289 to 302 Engine
  • Fri Guy
  • Feb 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Feb 13, 2025
Fri Guy
F
H
Drivetrain 4R70W clutch friction/metals/piston set up questions for transmission guru
  • Hizdudeness
  • Apr 4, 2024
Fox 5.0 Mustang Tech Nov 15, 2024
slow84lx
T
Turning over fresh 347 stroker torque question
  • TexxDex
  • Apr 1, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 1, 2024
Bullitt347
Bought an engine for my project
  • 2stroke1971
  • Jul 7, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2024
limp
