  • 2005 - 2009 Specific Tech
3.73 or 4.10?
  • Thread starter Thread starter BlackGT01
  • Start date Start date Nov 24, 2008
BlackGT01
153
Ottawa, Ontario
Nov 24, 2008
  • Nov 24, 2008
Just bought a 2008 GT with an auto after being out of the mustang market for the last 6 years. I am happy to be back. This car will be a sunny day car and spend it's weekends at the track. What are you running for gears in your auto's? Am I going to see a big difference at the strip between 3.73's and 4.10's. I am not worried about fuel economy. That being said, I don't want anything bigger than 4.10's. Are they good for a tenth or two?
What should I expect to run with this car? My 01 ran 13.7's stock with a set of slicks.
Thanks
Fred
I love these cars. Pictures to come shortly.
stangzilla100
106
  • Nov 24, 2008
the 2008 autos come w/ a 3.31, i think. go w/ the 4.10's if youre going to race it at the track and not a DD.
whyask
735
Sacramento
Nov 24, 2008
  • Nov 24, 2008
ive run 3:73s, 3:90s, and 4:10's in my auto with a stock converter and I love my 4:10s !! Its my DD and track day car as well !
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Nov 24, 2008
  • Nov 24, 2008
go 4.10s, or dont do it at all. you are just going to wonder why you didnt do it right the first time. I have 4.30s in my manual trans and would not have it any other way!
whyask
735
Sacramento
Nov 24, 2008
  • Nov 24, 2008
What he said
klaw
343
Calgary, Alberta, Canada
Nov 24, 2008
  • Nov 24, 2008
Are 4.10's too much for F/I? I have a Whipple at 10 psi and bought 3.73's this past weekend. My '07 GT 5-spd came with 3.31's.
bradleyem
186
Columbus, Ohio
Nov 24, 2008
  • Nov 24, 2008
So, 4.30s work out pretty well with the 5 speed? I've been trying to decide myself, and I agree that I should do the tallest gears that I can deal with for a d/d. If I ever do a 6 speed swap, that would be the icing on the cake
stangzilla100
106
  • Nov 24, 2008
i have the HO and 4.10's and it can loose traction quite easily on street tires, have not tried w/ DR's or slicks. you'll be fine w/ the 3.73's
BlackGT01
153
Ottawa, Ontario
Nov 24, 2008
  • Nov 24, 2008
Thanks for all of the advice. I am going to indeed go with the 4.10's. Looking forward to the spring to be able to ride again.
klaw
343
Nov 24, 2008
#10
  • Nov 24, 2008
  • #10
Thanks! Will be installing the 3.73's over the next while. I'll let you know how they work out!
bigcat
May 1, 2005
3,015
7200 feet
Nov 25, 2008
#11
  • Nov 25, 2008
  • #11
i have not had any complaints with with the 4.30s. just dont plan on long roads trips all the time unless you can live with the increased RPMS for the entire trip. some whine that its too high, but around 3000 RPM is not too much for me.
StonePony
218
#12
  • Nov 25, 2008
  • #12
3.73 is the best all around gear for the automatic, especially with forced induction. You will reatain some highway performance with them and have better gas milage and still increase your acceleration over the 3.31 gears.
If you drag race you should determine with your setup if you still want to be in 4th gear when you go through the traps, because depending on tire diameter you could be forced to shift in to 5th before the end of the 1/4 and that is not optimal.
Five Oh Brian
552
Pacific Northwest
Nov 25, 2008
#13
  • Nov 25, 2008
  • #13
Supercharged automatic GT here. 4.10's and wouldn't have it any other way with the S197 automatic. 4.30's in a manual trans car work great with the deeper overdrive ratio (.68), but 4.10's is pushing it for automatic's overdrive (.71).
I do need taller drag radials, though, as I'm in 5th gear about 200 feet before the end of the 1/4 mile with short 275/40/17 BFG drag radials, yet still turning 12.30's @ 111+.
Way back before the supercharger, when it was just 4.10's, tune & drag radials, my 07 GT automatic was running 13.40's @ 102+. Added a big stall converter and went 13.20's. That was with 100% stock engine, exhaust, and suspension, too!
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
Help with AFR reading
  • dz01
  • Nov 14, 2024
1965 - 1973 Classic Mustangs -General/Talk- Jan 8, 2025
GOvert
G
