3.73??
  • Thread starter Thread starter lamakina
  • Start date Start date Jun 3, 2009
L
lamakina
  • Jun 3, 2009
hey guys.. i'm new here and i would like to ask you a question...
i have an 89 ford mustang with an AOD tranny... i got 2.73 gears on the back... so i'm thinking about getting new gears on the back.. i would like to ask you .. what gears would you all recommend??
my friends says 3.73
and my questions..
if i get 3.73 how big is the differene.. and if i'm going 70 or 75 what yould my RMP's would be???? i dont want my RPMS to be to high.. what do you all think??
with 3.73 gears would take off faster.. but what about top end speed?
thanks in advance?///
skunk21
1,203
Taxachusetts
Jun 3, 2009
  • Jun 3, 2009
1st gears are always a good idea but there is a slight trade off. It's going to eat into your mpg some. 2:73's are really tall and bogg the motor down so going to 3:73 are going to be night and day. I'm not an auto guy so I'm too familiar with your gear ratio's. Alot of the times it's recommended that aod guys run 4:10's and the 5spd guys run 3:73's. I still think 3:73's would be a great gear though but I'm sure the auto guys will chime in. I have a .63 5th gear in my T5 and run about 2,100 rpms or around there at 65 so 70-75 would be a few hundred more, to me that isn't bad at all. I got a feeling you wouldn't be that far off. You will not believe the difference in the car though.
Beasty306GT
671
Oxford,Mass
Jun 3, 2009
  • Jun 3, 2009
Everyone says 3;73 for 5 speed.....and 4;10 for an auto......its ur choice really
STP72
109
  • Jun 3, 2009
All depends what you want.. 373's if you do alot of highway driving and 410's for in town use.. I have 373's in my AOD.. It felt like I added a supercharger I could only imagine what 410's are like. I wish I went with 410's to be honest. On the hwy I am running around 2000rpm at 60-65 mph 410's you will be 200-300rpm more I figure.. I say go with 410's I WISH I DID.. Also put in a shift kit and do the epoxy mod to the VB will be alot more fun to drive
L
lamakina
  • Jun 5, 2009
what brand gears??
so.. i'm going with 3.73 since i run highway.. ans street..
but know the questions is..
do i buy the complete bearing kit.. .. what brand??
and for the gears...
FORD RACING..??
RICHMOND GEARS??
MOSER GEARS???
Turd Tops
103
South Lyon , Michigan
Jun 5, 2009
  • Jun 5, 2009
This my thinking only
Alot of freeway driving...3.55
Some freeway driving.....3.73
No to very little freeway driving...4.10
Some street and alot of track time...4.30
I would use this for a 5-speed but with the AOD i would start with 3.73's
STP72
109
  • Jun 5, 2009
You can't go wrong with ford racing gears or Richmond gears
While your doing the gears I would rebuild the Trakloc and replace bearings and seals at the same time. 373's are a fun gear you will like them. I want to try 410's next just to see what the difference is between 373 and 410's..
ill advised
656
10
West L.A.
Jun 5, 2009
  • Jun 5, 2009
You will definitley notice a jump with the 3.73, especially in "passing speed". My AOD is more for cruising/daily driving so I'm satisfied with the 3.73. I'm not looking for max performance. Otherwise I would have upgraded the stall converter, which is what you really need to get these cars moving. Even with the gear it still feels like a dog off the line. A quality stall isn't cheap though.
I'm running Ford Racing's ring & pinion in both cars. Summit carries several install kits.
skunk21
1,203
Taxachusetts
Jun 5, 2009
  • Jun 5, 2009
Gears go ford racing, they are quiet and a nice gear set. The ford racing bearing set are also a great choice , since you got the rearend open I would refreshen the whole thing. The ford racing M-4210-C kit comes with everything inside a 8.8 rearend, pinion/carrier bearings, axle bearings/seals etc. The B kit will also due the job minus the axle bits.
also a good time to rebuild the traction lok if you already haven't done it, the M-4700-C kit from Ford has the carbon fiber disc set, the B kit is the standard clutches. have fun
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Jun 5, 2009
#10
  • Jun 5, 2009
  • #10
To be honest, with an AOD i didn't like 3.73's. It was great for drag racing but in terms of having a top end...it sucked. Anything past 80MPH seemed like you were running out of gear and with an AOD and 3.73's your top speed was around 100MPH at WOT since you can't shift into OD at WOT limiting you to 3 gears.
So for a freeway driver, i would stick to 3.55's or even 3.27's. If this car is your weekend cruiser, then by all means go 3.73's or 4.10's.
WHen i had my '03 GT i loved the 3.27's. Everyone told me to do 4.10's or 4.30's but i loved how i could be in 3rd and pull hard past 65MPH and shift into 4th.
Part of me wants to take my 3:73's out and go to 3.27's with my new 5-spd swap setup.
the pony boy
358
Jun 5, 2009
#11
  • Jun 5, 2009
  • #11
i have 2 mustangs one with boltons and 373's with a pa valve body and the other with 410's shift kit and gt40 kit.i think the 373 car is more fun and more daily driveable than the 410 car.the 410's with the flowmaster exhaust was to much on the highway. phil
skunk21
1,203
Taxachusetts
Jun 6, 2009
#12
  • Jun 6, 2009
  • #12
Mike you would hate yourself taking out the 3:73 in a 5spd car. The only other choice I would have done was maybe 3:55's, but for a weekend/pleasure car leave the 3:73's, a 5spd car has plenty of running room with those gears.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Jun 6, 2009
#13
  • Jun 6, 2009
  • #13
Well i'm going to give it some honest miles with the 3.73's first before deciding what to do. I was going to swap them when i had the axle out, but i decided to try it first.
The only reason why i want to gear it down is that I will be doing a LOT of freeway driving. But i'll wait and see how it is with the 3.73's first
Dino Dino Bambino
1,673
90
79
Cyprus
Jun 6, 2009
#14
  • Jun 6, 2009
  • #14
As an auto owner I'd suggest the following:
3.73: For a torquer 302 with a maximum rpm of 5500 or less.
4.10: For a higher HP 302 with a maximum rpm nearer to 6000.
I have a 3.73 and for freeway driving it's absolutely fine and delivers good gas mileage.
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
