I really wouldn't go bigger than 24s without a tuner and willingness to have idle and starting issues. Turning up the pressure will help with atomizing the fuel, but without a tuner, it will still have issues and will run rich in open-loop (i.e. when it's cold and at wide open throttle). The way I see it is once you have done enough to the motor where you NEED a tuner, you will have maxed out the 19# injectors anyway. So until then, don't bother.
What John said
Sticking to the 94-95 pcm's
They are load based where the Fox body pcm's are rpm based
Having said that ... The pcm determines load from the meter's output
When you move away from OEM 19's & meter and use the aftermarket
meter's cheat method (running a larger set of inj's and meter with no
pcm adjustment) of matching meter to inj size the load reported to
the pcm starts to become skewed
With 24's it is not too bad
but
As you move to 30's the error grows larger
and
With 36's and 42's ... it is WAY OFF
So you see ... there is a WHOLE LOT more going on here than most
are even aware of in this situation
It is most important to understand this fact :Word:
That whole aftermarket meter cheat method was developed for the
Fox Body Stangs and their RPM BASED pcm's
So you see ... you are using a method not designed for our 2 year run
of pcm's found in our cars here
anyway ............
For a mild combo at say mid 200 rwhp levels ..........
You can run 19's at elevated fuel pressure
24's and a meter caled to match them run at elevated fuel levels have
supported 300 rwhp or a bit better but those inj's are being worked for all
they got to give ... and in some cases ... beyond
Finally ... Like John said
When you start modding you will run out of inj (OEM 19's) pretty quick
You always reach fuel limit before meter limit .........
One of those things where you can prick your finger
and
Write it on a white sheet rock wall
As a matter of fact ... the OEM meter will take you to around the 300 rwhp
mark if you have pcm access
Summing up ... you can somewhat tune a 94-95 with dizzy twisting and
playing around with fuel pressure
BUT
There is only so much you can expect from that method
So Ron ... have we caused you to think about anything
Grady
