Can't wait to see the Mustang GT get absolutely smashed by the new V6 Camaro...all while getting 26mpg on the highway (rated, obviously higher in real world). It also has a smaller engine than the Mustang's V6 at 3.6L.
Here are all of the release notes/pages on the Camaro which was revealed live, today.
GMnext | New Chevrolet Camaro | GM
And the notes on the powertrain:
Powertrains
An advanced, efficient 3.6L direct-injected V-6 with variable valve timing is standard on LS and LT models. Direct injection technology helps the engine deliver more power through increased efficiency, while maintaining fuel economy and lowering emissions. That means less fuel is consumed and lower emissions generated – including a 25- percent drop in cold-start hydrocarbon emissions.
The Camaro’s 3.6L engine also employs variable valve timing to optimize performance and fuel economy across the rpm range. It is rated at an estimated 300 horsepower (224 kW) and 273 lb.-ft. of torque (370 Nm). A six-speed manual transmission is standard with the 3.6L engine; a Hydra-Matic 6L50 electronically controlled six-speed automatic, with TAPshift control, is available.
The high-performance Camaro SS is equipped with a powerful 6.2L V-8, with a choice of a six-speed manual or six-speed automatic transmission. Standard, manual transmission-equipped models receive the LS3 engine, estimated at 422 horsepower (315 kW) and 408 lb.-ft. of torque (553 Nm). The LS3 debuted on the 2008 Corvette and uses high-flow cylinder heads based on the Corvette Z06’s LS7 engine to enable great low-end torque and high-rpm power. It is paired with a TR6060 six-speed transmission.
A new, L99 V-8 engine is used on automatic transmission-equipped SS models. It is
based on the LS3 and carries all of its high-performance design features, but also
includes GM’s fuel-saving Active Fuel Management feature. It enables the engine to run on only four cylinders during light-load driving conditions, such as highway cruising, to improve fuel economy. The V-8 is estimated at 400 horsepower (299 kW) and 395 lb.-ft. of torque (535 Nm); and it is matched with a Hydra-Matic 6L80 six-speed transmission. This combination delivers an estimated 23 mpg on the highway.
Only one that'd be close is maybe a 'vert auto. Those numbers are really closer to non-PI GTs.
